I have a Bally Supersonic backglass that has large pieces coming off the back. What is the best way and product to glue these back to the glass? Anyone ever reattached big pieces that have come off?
Krylon Triple Thick but that only is preventive maintenance and tiny flaking setting, not a major repair. Search online, I know there are blogs documenting what to do.
Super Glue Gel works nice. DON'T get it on your fingers or the weights you use to keep the paint down.
A tiny amt goes a long way!
I will say that you may want to try Krylon Triple Thick afterwards using the Saran Wrap method. Leaving it in the hot sun seems to soften the paint flakes so there's less cracking of the paint.
Don't forget to leave the Backglass alone for at least 24 hrs before you try to remove the Saran Wrap.
Good luck! Post Pictures!
Ok I have read through old posts but I am still confused. I have large pieces of the art lifted from the glass but still attached to the good art. Do I superglue it down then use triple thick and Saran wrap process or do I spray triple thick between the glass and the art then use the Saran wrap method on the back at the same time I spray inside? Any help would be appreciated as I don't want to screw this up. Thanks
This page was printed from https://pinside.com/pinball/forum/topic/bally-ss-backglass-flaking and we tried optimising it for printing. Some page elements may have been deliberately hidden.
