Decided to try and fix one of the non working Squawk and Talk boards. This one came from a Mr. & Mrs. Pacman. First, I had to undo the soldered wires on the EE jumpers that I made while troubleshooting Fathom. I double checked the rest of the jumpers on the board with pinwiki and seems to be correct.
Figured out how to get the LED flashing, it depends how the board is connected to power supply. At first I connected +12 volts to TP3, and -5 volts to TP4. The LED does not flash in that setup.
Read another repair guide http://www.pinwiki.com/wiki/index.php?title=Leon_Borre_Bally_-61_Squawk_and_Talk_Sound_Repair
which says "12 volts at J1, pin 17= 12 pin 16 = ground . Make a connection between C14 and C15 both - sides ... -5volts arriving at TP4". The LED does flash when I hook up to power that way. Perhaps it's simply the C14-C15 connected by an alligator clip wire that causes LED flashing, not sure.
At first the LED was flashing 2 times and stopping. According to the guide this means U11 is bad. Started swapping different PIA Chips into U11 but no change. What I noticed was if I wiggled the jumper wire connected to C15, then rebooted the board it did occasionally get 4 flashes. So the logic side of the board was working sometimes! However no sounds were produced out of the speaker when pushing self test button after a successful boot. Decided to leave that same PIA chip in U11 that managed to boot up in place and it's still in there now. I checked all the connections from U11 pia chip with the schematic and buzzed it out with voltmeter in continuity test mode and it all tested good. So the socket for U11 should be good. Also I tested all the chips on the board for 5vdc and they all measure good.
Since the problem seemed to be related to a bad cap (C15), decided to re-cap the entire board with a Great Plains cap kit. My best guess was maybe the 5volts dc is good but there could be not enough current to consistently power all the chips through a full boot?
Now that the board is recapped, I am still mostly getting 2 flashes. Occasionally if I play around and boot it up many times, it will get 4 or 5 flashes. However I thought it's only supposed to flash 4 times? So five flashes seems bad, correct? Usually the only thing that gets it to go past 2 flashes is rebooting by pulling and reconnecting the alligator clip wire hooked up to C15 which causes alot of static on the speaker and a little spark. (probably bad for all the chips). Whenever I get the 4 or 5 flashes, pushing the self test button produces no sounds out of the speaker.
Now, I am stumped what to do next to fix this board. I have access to a scope if needed. What's the next step to get this board fixed?
