I've started repairing a Spy Hunter I picked up last year. First of all I repaired the power module all voltages were good so I plugged in the other plugs and fired it up. C10 popped on the cheap squeak deluxe but I got 7 flashes on the mpu. So it went into attract mode and coined up but no sound. I pulled off the sound board replaced c10 plugged it in to test before I mounted it and I got some sounds so I mounted it and c10 blew as well as one of the fuses on the power module. So it seems that the board is grounding off of something also the button on the coin door for going through the test modes isn't working. I tried using a different working mpu with no change. I checked continuity on the wires in the switch and I was able to trace one of them all the way to the backbox but not the other so I'm guessing there's a break possibly but I'm not 100% sure that I got the right wire in the backbox. At this point I'm not 100% on where I should start but I'm sure someone on here can point me in the right direction thanks in advance
Jim
#spyhunter
