I have no flashers working now. All other solenoids work. I checked the 43vdc 3/4 amp fuse and it’s good and getting 43vdc. I checked continuity from the transistors to the other side of each string so that not an issue. I went to each string of bright lights, flashers, and had 43vdc or 20vAC at the start and each point through the string so no bad bulbs or plugs. The only issue I can think is the 4.ohm resistor. It has 43vdc coming in but on the other side if I test voltage while touching a grounded bulb to it, added load, the 43 goes to 0. Bad resistor?
