Hi All,
Here's the history....
I have a Bally Speakeasy. The control lights, attract mode and roulette wheel were not working. I found a bad bridge rectifier on the transformer board and replaced it. After that, the existing problems were still there, but now no displays (the bottom display has a glow, but the score display's don't), the game won't boot up and the test button doesn't do anything.
It seems as though machine was not getting 43VDC, the only correct voltage on the rectifier board was at TP1. No voltage at J5 across green and orange wires.
In order to help troubleshoot (I knew it would be fruitless), I replaced the rectifier board with a new one with no change to the symptoms.
Any suggestions as to where to go from here? I'm trying to hunt down a transformer, but it seems unlikely that a transformer would go bad.
-Thanks
