Just when I think I know what I am doing reality sucker punches me. I have killed my Tunnel feature on my Bally Space Time. I would be grateful foe any help. Ok you can point and laugh if you like. I probably deserve it
I have been restoring/refurbishing/abusing a 1972 Bally Space Time. Before I began working on the pin, I did get it functioning 100 percent. So I know everything worked correctly before I messed with it.
I just recently finished the cabinet and back box and am now I am waiting on the playfield to cure post clear coating before repopulating it. In the mean time, I Installed all of the cabinet and back box components and then began testing what I could without the playfield. I believe I have everything functioning correctly expect the Tunnel Freature/Flash Motor.
From the Installations and Operation instruction, the Tunnel feature works per the following.
Tunnel Feature:
FEATURE OPERATION AND SCORING
The “flash motor” unit controls the tunnel flashing lites and tunnel scoring.
The flash motor unit is controlled by the “tunnel relay” which is energized
when a ball goes into the outhole, left or right (eject) hole and when the
ball hits either “start tunnel” target. The flash motor stops when ball goes
over shooter alley roll-over or whenever the “collect relay” is energized to
score tunnel scores. The flash motor also stops when the game is tilted or
completed.
Skill Shots: To register a high score when ball is in shooter alley, the
ball shooter should be released so ball will go over shooter alley roll-over
when “5000” score lite is lit, and the ball should be i with just the
right force to go into “collect tunnel” lane at top of playfield.
When I manually engage the outhole, right or left hole, a switch on the tunnel relay sparks and the pin powers off (fuses do not blow nor does a GFCI trip). This is the switch with two yellow wires and one end of a 3300 ohm resistor on one blade. The other blade of this switch has a orange/red wire and connect with the other end of the resistor. (See attached pre cleaning picture of switch).
I believe I have checked all of the switches on the tunnel, start tunnel, outhole, left &right relays. They all looked correct however, I did ohm they out to be sure.
I also double checked the all of the wiring of relays, Flash Motor, and relaxing coil by comparing them with pre abusing pictures. They all matched the original wiring.
I checked the resistor out of circuit and it was pretty bang on 3300 ohms.
All of the coils also checked ok.
I am not sure if this is useful or not but, when I took the sparking switch off circuit and manullay engaged the outhole, left&right holes the pin did not shut down and these relays seem to function as they should.
Attached is the schematics for your convenience.
I am not sure what to investigate next. If you have a suggestion, I would be very grateful.
Phil
1E90B181-09CD-44B7-9AF0-DB0253CA4A5E (resized).jpegBally_1972_Space_Time_Schematic_Diagram_continuous.pdf
