The right slingshot on my xenon was stuck on. After doing the tests, found the SCR bad, replaced SCR, and slingshot would not work. After doing the other tests-checking coil, re-checking new SCR, and switches, I found when I jumped across the switch diode and made the switch, it would fire. Assuming the diode was bad, I replaced it with a new one (1N4004), soldering it in the same orientation (unbanded end on wire terminal). Still didn't work. Out of ideas, I switched direction of the diode and it works, but occasionally the coil sticks until a bumper or flipper is hit, then it releases. Still very confused as to what is wrong. Any ideas would be appreciated.
