As I said in my EM pinball hangout post I was gifted a Bally Sky Divers to work on in my "spare" time.
I went through all the switches/coils to make sure the were free and moving which everything was. Nothing looked burnt or rusted stuck, and other than being quite dusty on the outside, the inside was clean.
I added some credits to the replay wheel, set the score to a random number and pushed the credit button. The score will reset to zero, replays start counting down, not stopping until it reaches zero. The brown disk assembly in the upper part of the back cabinet (label nearby says "thumper control unit" will continue to click away and the score motor unit in the base cabinet will keep spinning. I found if I lift up on the big coil in the middle of the cabinet attached to a row of switches everything shuts off and until I add some credits and push the credit button. If I unplug it instead of tripping the switches and plug it back in the thumper control unit will resume clicking and and score motor unit will start spinning without me touching anything.
When I add more credits and a random score it will again reset score, continue to count replays down to zero and stop, thumper control unit(?) clicks away, and score motor spins until I unplug it or lift up on the coil and trip the switches. Done this multiple times trying to see if I could see something obvious but nothing stands out. Don't know if ties into my problem but the light bulb behind the "er" in divers will start flashing.
Don't want to randomly start pok'n and prod'n and really mess something up. Ideas what to try 1st? 2nd? 3rd?
