(Topic ID: 291157)
Bally Skateball - flipper issue
By stf_dnx
2 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by stf_dnx
#1 2 years ago
The 2 right flippers will stop working after one or 2 flips. Everything else is fine.
Any help is welcome, thanks
#2 2 years ago
You may have cold solder joints on the flipper relay that is on the solenoid driver board. Soldering these required.
Also check your end of stroke switches on the flipper assemblies. They need to be closed and then open completely with the flipper bat up.
#3 2 years ago
I would check the switch for the right flipper button in the cabinet, and then the wiring that goes to the lower right flipper coil lugs/EOS switch. The power daisy chains from the lower right to the upper right. The relay is probably fine if the left hand flippers continue to work.
#4 2 years ago
Thank you for quick answers, i will check these and let you know
#5 2 years ago
Bad solder it was. Thank you pinsiders
Displays
PinballSolutions.eu
Displays
$ 8.00
Third Coast Pinball
$ 9.00
Cabinet Parts
Third Coast Pinball
Cabinet parts
Cabinet Parts
Volcano Pinball
Cabinet parts
This page was printed from https://pinside.com/pinball/forum/topic/bally-skateball-flipper-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
