I noticed that side rail nails are available in 3/4" and 1". The originals are 5/8" and I fear the 3/4" would be too tight. Does anyone know where to get 5/8" ones?
Quoted from JoeGrenuk:Nip off, say, an eighth?
Always possible but not ideal for new holes. I was hoping someone sold them in 5/8".
Quoted from 20eyes:I used screws #4 size I think . Much easier.
Easier to remove in the future as well!
1/2 is available from McMaster-Carr.
An 1/8th smaller than 5/8.
http://www.mcmaster.com/#97810a210/=xjvoro
Not sure if the same for Bally, but PBR sells the exact size twist nail for Gottliebs. I have never found them anywhere else.
I found that if you use 3/4 ones the tip will protrude out the other side. I use side cutters and snip a small amount off and they worked fine. When you cut them off hold your cutters at an angle and that will leave a point so they drive in easier if you are not going in existing holes.
Also, how do you hammer them in without indentations? What tool.
Vid I am not sure I would like the look of rails held on with screws...can someone please post a picture of it.
Thanks,
Dave
The ones Steve had last time i ordered some were a little to long. I just held onto them by the shank with a set of needle nose pliers, Then just run it along a grinding wheel at an angle to shorten it up some. By Turning the nail with the pliers, you can still keep a point so that you can drive it in.
As for how I drive them into the cabinet. I fold up a napking a little and then place it over the head of the hammer and hold it on with electrical tape. That way i have the strength of the hammer, but a light cushion to not damage the head
Quoted from DnDPins:Vid I am not sure I would like the look of rails held on with screws.
Just make sure you get decorative head, low profile screws
sheet-metal-screw-phillips-truss.gifQuoted from vid1900:Just make sure you get decorative head, low profile screws
hmmm, i might use this for my restoration.
This page was printed from https://pinside.com/pinball/forum/topic/bally-side-rail-nails and we tried optimising it for printing. Some page elements may have been deliberately hidden.
