I've had this pinball machine a couple of weeks. Starting a couple days ago, the 100 (or optionally the 100/1,000 or 1,000) bell ringer solenoid started sticking. It is not activated, if I tap the plunger it will drop back down. I noticed the 100 relay was stuck on, the paper label was black and it was really hot. I turned it off, let it cool down, and cleaned all the switches on the relay. When I started it back up, I fired it manually a dozen times and it didn't stay on, however after firing one or two times, the bell solenoid tends stick on.
1. Can I clean it or does it need to be replaced? I don't see a spring so I'm assuming returns by gravity.
I'm new to pinball machines and still reading through the guides and https://pinside.com/pinball/forum/topic/em-schematic-fully-described-from-beginning-to-end-bally-bon-voyage recommended by rolf martin.
I have a digital multimeter and can solder.
