Quoted from Flip-it-good:have the same segment missing from the Credit/Ball display. All other displays are OK...
Every 5-10 seconds or so the segment lights up, then out again.
Pull out the display, very carefully check the solder connections on the display glass connections to the circuit board. Resolder any that look cracked/fractured.
If they look good, the next thing to check/suspect is the driver transistor for that segment (it's called the 'e' segment). Transistor Q17 on the display board drives that 'e' segment. It's a MPS-A42 transistor. Presuming you don't have spares, I suggest carefully swapping it with one of the other segment driver transistors, say Q15 for example.
If the same problem stays, the next suspect would be the 4543 decoder chip on the board.
If the problem moves to another segment, then that transistor you moved from Q17 is suspect.
If the problem magically goes away, that transistor you moved from Q17 is suspect and might come back down the track.
