(Topic ID: 145350)
Bally playboy blowing fuses (Issue Resolved)
By DnDPins
6 years ago
  • 39 posts
  • 9 Pinsiders participating
  • Latest reply 5 years ago by Shoot_Again
#1 6 years ago
I am very appreciative of those experienced technicians who respond to these tech help posts. In order to be considerate of their time, I have used Vids post as a template to provide the required information:
1) Bally Playboy 1978
2) Bought as a project pin and I am not aware of the last time it worked
3) Since it blows fuses, I cannot run diagnostics
4) Bought from a collector who took it in on trade. Based on the ball swirl, it was obviously routed
5) It does not appear that any mods were done
6) There are no aftermarket boards installed
7) No obvious battery corrosion
8) Incandescent lighting
9) No smell
10) No obvious past work performed...not even changing the rubber rings
11) I do have a Volt Meter
12) I can solder but am I little hesitant to solder on the boards. My brother does that for me though
13) I am in central NJ
14) I will post pictures tonight
Details on work we performed to date:
1) Repined J1, J2 and J3 going to the rectifier board (Most of J1 was showing connector burn and the first pin or two on J2 also had some burn)
2) Installed a new rottendog bridge rectifier board and verified all fuses
3) Plugged in only J2 and confirmed each test point had proper voltage
4) Checked under playfield to see if there were any visible issues. None found
No issues up to this point
Next re-connected all boards and the following fuses blew: (did get a green light on the MPU)
F3 4A, F4 5A and F5 20A (I heard a humming noise before the fuses blew)
Replaced the fuses and unplugged all connectors except J3 and J4 on the solenoid driver board and blew F3 and F4.
Other boards I have:
Since I have several Bally early SS machines using the same boards; MH, SnS, HG I have know good boards. Additionally, I have a spare Alltek MPU.
I have got additional fuses and am ready to continue troubleshooting, what are the best next steps? How do I narrow down the source of the blown fuses?
Thanks,
Dave
#2 6 years ago
It's good to have some Fuse Breakers made, so you don't blow through a bunch of expensive fuses.
0
The next step is to just plug the rectifier board in, with only the power connector plugged in.
Make sure you have the proper voltage on each test point:
TP1 - (4.6 - 6.4VDC) this is protected by the F1 fuse, and is Bridge Rectifier #1. This supplies voltage to the switched lamps.
TP2 - (160-250VDC) This is protected by fuse F2, and is the group of diodes CR1-4. This supplies the voltage to the displays.
TP3 - (11-16VDC) Fuse F3, Bridge Rectifier #2. This latter becomes the 5VDC that powers the game's logic circuits on the Solenoid Driver Board.
TP4 - (6.3 to 8VAC) Fuse F5. This is the GI lighting circuit.
TP5 - (40-49VDC ) Fuse F4, Bridge Rectifier #3. This powers all the coils in the game.
If all of the above are correct, plug in the driver board with nothing else plugged into it.
#3 6 years ago
Take a step backward. Unplug everything from the rectifier board except J2. Replace F3. F4 and F5 can wait. Unplug all connectors on Solenoid board. Apply power and see if F3 survives. If it does, install a known good Solenoid board and connect only J3. Connect J3 on rectifier board. Leave all connectors on MPU unplugged. Does F3 survive with second solenoid board?
#4 6 years ago
I would pull the driver board and test all the transistors. I suspect you will find several shorted. Also the knockers on these early SS games are not fused and often short.
Don
#5 6 years ago
I followed Cody's advice:
1) I unplugged everything from the rectifier board except J2 and only replaced fuse F3
2) Unplugged all connectors from the solenoid driver board (there are no connections anywhere on any other boards)
3) Turned on the power and F3 did survive
4) I installed a known good solenoid driver board and only connected J3 on the driver board. I connected J2 on the rectifier board and F3 survived
5) I now installed fuse F4 and F5. I connected both J2 and J3 on the rectifier board and J3 and J4 on the power driver board
Results:
Fuse F4 (5Amp) blew instantly all other fuses are fine
What next?
Thanks,
Dave
#6 6 years ago
If it never worked, it is possible that your game has a miswired connector plug(s).
The 2 numbers before each connection is the wire color.
Bally did NOT use standard color codes.......
#7 6 years ago
OK by connecting J4 you introduced more circuitry into the equation. That hooked up the coin lockout coil and that could be popping your fuse. I was shooting for all fuses surviving POST and getting some blinks on the MPU before hooking up any loads.
Like VID says, troubleshooting blown fuses can get expensive and circuit breakers are the way to go, and it wouldn't hurt verifying your cable colors.
I would continue on with the good SDB and worry about the fuse-eater after you get some circuit breakers.
#8 6 years ago
Thanks guys.
1) Where do I get what I need to make / purchase the circuit breakers?
2) I was very careful and did confirm the cable codes when repining J1, 2 and 3 for the rectifier. I will now verify the pins on the connectors going to the power supply.
Note about POST:
When I first connected everything before I blew F3,4, and 5, I got a green light on the MPU. Also the coin door coin slot lamps were light.
How do I continue on with the SDB (known good) without blowing fuses; leave F4 out? I was not sure if F4 was needed to be in place. What should be my order of operations to continue through to post?
#9 6 years ago
Quoted from cody_chunn:
I always cut one wire off the coin lockout coil and tape it up on any service call.
No one on earth is ever going to put money into a turned off pinball machine, so you don't need it.
#10 6 years ago
Quoted from DnDPins:
Those lights and the GI playfield lights will always be on, even if the MPU does not boot.
I always laugh when I see a CL ad that says "Lights up, but game does not start".
#11 6 years ago
OK...made some progress:
It turns out that I reversed two orange and green wires on J2 and J3 on the rectifier connectors. Once I fixed that I systematically plugged in all the connecters to all boards and no fuses blew. Additionally, everything works except ALL solenoids. I have verified the voltages at the rectifier board and they are all good and the SDB is a known good one. I was also able to run the diagnostics and no solenoids fire during that test. I also verified that the playfield fuse is good.
Is there any thing which globally disables all solenoids on the game?
Thanks,
Dave
#12 6 years ago
Bump for a little help!
#13 6 years ago
where exactly? at the test point or at J1 ? do you have 43V DC at A2J1-6 over ground? do you have 43V at the playfield fuse ? ...at the coils?
#14 6 years ago
I measured all voltages at the test points on the rectifier board and they were good. I also confirmed that 45v is getting to the coils.
#15 6 years ago
#16 6 years ago
Quoted from vid1900:
I have had people try to put money in to games that were not only off but the glass was removed because I was working on them. Give people the slightest chance to be stupid and they will.
Is the game fully booting? Do you get the correct flashes on the MPU? When you press the diagnostics button, does it go through the display tests, sound tests, etc correctly?
#17 6 years ago
Quoted from WonkoTSane:
The game does fully boot
I get 5 or 6 green flashes before it goes solid
I can get fully through the diagnostics. Everything...however when I get to the solenoid test, none are activated.
#19 6 years ago
Yeah, I know you are probably right!
If you ever put the game back on route, be sure to reconnect the coin lockout coil.
But for home use, cut one wire, and tape it off.
#20 6 years ago
Previously I was able to get the MPU to boot with 6 flashes and then the game would go into attract mode. If I started the game, none of the solenoids would fire but everything else worked. If the game failed to complete it's boot, would it still get to attract mode? I was able to run the diagnostics however none of the solenoids would fire.
Current status:
After swapping MPUs and SDB, I now have an MPU with the LED locked on. Even when I switch to a different MPU, the LED is still locked on. What does that tell us??? I would think it is not reset circuitry since it is the case on multiple MPUs.
OK...I think I have it narrowed down to 2 issues:
1) I get a little over 6v on TP1 on the rectifier board however on the SDB the 5v test points read a little over 4v. What could cause the voltage to drop 2v between the rectifier test point and the SDB? Bear in mind that the MPU was previously able to boot so therefore the 5v must have been good. I did have to remove the connectors a lot in the process.
2) I get 45v on TP 5 of the rectifier board and about the same to all coils (I did not check every one) on the playfield however for some reason I do not think the MPU is recognizing the 45v
All of this seems to point to connectors / cable issue. I already re-pinned all connectors going to the rectifier board and will order the smaller connectors so I can pin the others as well but for now, can someone point me to which pins on which connectors allow the MPU to read 43v and which one carries the 5.4 from the rectifier board to the SDB?
Help with this would be greatly appreciated!
Thanks,
Dave
#21 6 years ago
Bump for a little help.
#22 6 years ago
Update:
I resolved the fuse blowing issue as I found 2 of the same color wires were swapped on 2 rectifier connectors. Once I repined and plugged everything in (except the sound card) the game plays perfectly. As soon as I plug in the sound card and power on the machine, the right sling solenoid fires and sticks on. I was able to clear that condition by unplugging everything and plugging back in without sound card however once I plug it back in, the right sling gets stuck on again.
I have verified all of the wires on the connector going to the sound card but I have not yet repined that connector. Is it possible that the connector could be causing this issue???
Thanks,
Dave
#23 6 years ago
Bump for "a little help here" (in my best Homer Simpsons voice)
#24 6 years ago
Did you try swapping the sound card with your HGT card?
#25 6 years ago
That sound card uses the solenoid address data as control signals. Something is fouled up on that sound board causing one of the address lines to lock active.
Do you have a logic probe? Sound board J1 pins 1, 2, 3, 4, and 12 should all be pulsing...or around 2.5VDC measured with a meter.
What do you measure on those pins?
#26 6 years ago
Thanks Vid and Cody I will check the sound board. I did swap in my Alltek MPU board and it works fine. Does that point to a chip on the original MPU? Which chip should I probe or order. (I am going to order a probe tomorrow)
Thanks,
Dave
#27 6 years ago
There have been so many fixes you need to state what's going on with the MPU. If the LED is locked on, try shorting pins 39 and 40 on the CPU U9 together.
#28 6 years ago
Quoted from dothedoo:
The current state:
If the sound card is not plugged in, the game boots and plays without a problem. As soon as I plug in the sound card, the next time I power on the machine, the right sling shot sticks on (I quickly turn the machine off)
I can clear the stuck condition by unplugging all the cables and then as soon as I plug in the sound card again, the same thing happens. Seems like the problem is stemming from the sound card however I swapped the MPU with an Alltek board and it now plays fine. So seems like a logic problem on the MPU which is triggered by the sound card???
Thanks,
Dave
#29 6 years ago
If you can get the pins out of J1 without mangling them, mark their position clearly so there's no mistake, and pull pins 1, 2, 3, 4, and 12.
Same kicker lock or clean boot?
If clean, add one wire back at a time, cycling power between wires. Did one specifically cause the kicker lock condition?
#30 6 years ago
Re-pinned J3 going to the solenoid driver board and now none of the solenoids fire (and I do not get the 7th flash at boot up) however the flipper work when a game is started.
Is there one or two pins I should specifically check to continue troubleshooting?
Thanks,
Dave
#31 6 years ago
Well, the 7th flash is for the zero crossing ckt, so sdb j3 shouldn't affect that. Also without the 7th flash, nothing else will work, so let's look at that.
Do you have anything at mpu tp3? Should be around 21 vdc.
If not, anything at tp5 on the rectifier board? Should be 43vdc. If not check f4.
If you got the 21 v at mpu tp3, check u14 pin 5, should be 4.5 vdc. If nothing, replace u14.
If the 4.5 is there, replace u10.
#32 6 years ago
When I swapped with my HGT sound card the same thing happened.
Since the same thing happened with the HGT sound card it would seem the problem is not the card. So what else can it be? Soundboard Connector? Other .156 connectors going to SDB?
BTW...I have a logic probe on order.
#33 6 years ago
Fascinating. If it's not the sound board itself it's something to do with the inter-relationship between it and the other boards. When you tried the HGT board, did you mount it? I ask because isolating it from that back plane ground affects the circuitry. Have no idea why.
You posted earlier that you installed a alltek board and then the game worked properly? With the sound board connected? Is that accurate? And with the original MPU the problem recurs?
#34 6 years ago
I mounted the board in the backbox in place of the original.
Since there have been a few phases of issues, I will review:
1) After replacing rectifier board with new Rottendog one and repining connectors, was blowing fuses. This issue stemmed from wires of the same color within 2 connectors being reversed. Once the reversal was corrected, the fuse blowing issue was resolved.
2) For a time, I had a case where I was getting a little over 6v on TP1 on the rectifier board however on the SDB the 5v test points read a little over 4v. I noticed that if I messed with J3 on the SDB the voltage increased and the MPU booted. This led me to believe the J3 SDB connector had an issue so I repined it. It seems that proper amount of voltage is constantly present now for the MPU to boot.
3) Current State - I swapped in known good SDB, MPU and Sound Boards in various combinations and have inconsistent results. Some times the games plays perfectly including sound. (with the exception of significant hum) With the game playing fully, I began to systematically re-introduce the original boards and as I do, a coil (different ones at different times) is locked on at machine start up. The fascinating thing about this is the issues spans boards. I figured, oh my solenoid is locked on in the logic but then as I swap the MPU, that same lock issue re-occurs with the different board....so I guess it is not logic. Then I swap out the SDB and again the same issue. Eventually, the condition clears and everything works until I try to swap boards again.
This seems to defy logic...my logic that is...
Thanks,
Dave
#35 6 years ago
The crappiest thing about restoring classic Bally is repinning ALL the female and male connectors.
You can never really have a 100% bulletproofed game until you do.
#36 6 years ago
Agree with vid...ALL connectors should be rebuilt and the color codes checked against the schematic.
But try this as a lark: get some alligator clip leads and jumper all the boards' GROUND Test Pin together. Any difference?
#37 6 years ago
Something made me decide to open up the plug on the power cord and it turns out the ground wire was disconnected. I bet this is the cause of the odd behavior however once I start swapping boards again, I will be sure. For now I am marking this as resolved. Thanks to all for your help!
Dave
2 months later
#38 5 years ago
I just picked this machine up and it has a blown F1 and bad R35.
I cannot find 8AG 3/16 amp fuses locally or 1W 100K ohm resistors.
Also the battery only reads .54V. MPU
So I am just going to order the first two items from marcospec .....
but as for the battery the manual lists E-00628-0003 but does not a rating on the battery for replacement.
I have read either getting a 4 slot AA holder and solder a diode in 1 battery slot. Or using Cr2032 litlhium coin style holder.
I am unsure what the correct procedure is. Could anyone please advise me what to order parts wise to either replace original or get that horrid battery style out all together?
I plan to deal with isolated driver regulator board first but 6 shipping for 8 bucks product seems silly I will need other things for sure.
#39 5 years ago
Currently will power on GI and coin slots only light, no sound and MPU solid green no blinks. So no boot.
