So I was playing my Bally Playboy with no problem, and then I turned it off to replace a bulb, and then turned it back on. I got a nasty sound from the speaker for a seconds and then turned it off. After turning it on again, I didn't get that nasty sound anymore, but the game won't start. I haven't taken the backglass off to look at the MPU (but will do so, of course). The electronics are AllTek (MPU, Solenoid, Lamp) and NVRAM (Sound).
I should say that I have been having an intermittent problem with the game not starting at power-up. I had had a bad display the last time, and after I removed it and reset the MPU, it worked. I was getting 2 then 4 flashes of the MPU when it was not working. Before removing this bad display, I had been having a problem with the pin not starting up on the first turn-on, but it would start up after doing this a few times. The current displays (#4 is just missing now) are all working fine.
