The "playmore" post on my Bally SpaceTime has a mind of it's own. I have worked my way through a few issues the previous owner considered 'fixes" and right now it works throughout ball play but does not go down/reset after each ball or between players or at end of game. It had been doing all these things but the issue was when in the down position it pulled down PAST the resting point and the coil held it there. It was so bad the ball could sit in it when in the down position. I found that the coil had been replaced with one that was stronger than the original. I put in the right sized coil and adjusted the DOWN POST relay mounted on the bottom of the playfield, it now goes up and down while the ball is in pay but as I mentioned does NOT reset properly.
ANY help is greatly appreciated, I feel like I fixed one problem and somehow created 3 others??!!?
