The saga continues... As I said I replaced U11 with a brand new 74LS93 ( https://www.digikey.com/product-detail/en/texas-instruments/SN74LS93N/296-3750-5-ND/377783 ) and it's still not working quite right. I busted out my 8-lead logic analyzer and checked as much as I could and I still think U11 is defective or something.
Per Tuukka I checked Sound Board J1, Solenoid J4, and even MPU J1 and everything pulses correctly and I don't see any bad solder joints. I did reflow Sound Board J1 just in case.
EDIT: When I went to remove the logic probe lead from the chip pin it came off very easily and turns out wasn't maintaining good contact. U11 Pin 11 is working properly. Leaving the below here for reference for anyone else looking to do this troubleshooting.
Quench 's awesome post in this thread ( https://pinside.com/pinball/forum/topic/bally-sound-board-as-2518-32-constant-tone#post-4363880 ) has served as a great troubleshooting step. Quench , I would love your input on below.
Quenchs Diagram
As far as I can tell signals are all working into U2 (Red):
U2 Inputs - Quench Post Red
And out of U2 into U1 (Blue):
U2 Outputs - Quench Post Blue
And out of U1 into U3 (Pink):
U3 Inputs - Quench Post Pink
And out of U3 (Green):
U3 Outputs - Quench Post Green
--- BELOW IS INCORRECT, WAS MISSING LOGIC PROBE LEAD ---
Which leads me back to U11... I never get an output on U11 Pin 11 in sound test mode, or even in gameplay mode with all kinds of pop bumpers, roll overs, slingshots going off. See below (zoomed way out, then way in):
U11 Relevant Pins All
U11 Relevant Pins Zoomed
U11 is a brand new chip. I have a second one which I may swap again but I feel like something else is wrong here.
This lovely german page ( http://www.pinball4you.ch/okaegi/rep_soundold.html ) points to U11 again as well. 74LS93 is recommended as a replacement for the 86L93 which comes with the game, and all the pinouts appear to match so I don't think it's a chip compatibility issue. I'll probably pull the sound board out of the backbox and check all the pins again.
Anyone have any ideas what would explain this?
--- ABOVE IS INCORRECT, WAS MISSING LOGIC PROBE LEAD ---
I'll continue working through the troubleshooting guide...
