Hello,
My Playboy works well. I re-flowed and checked all board//playfield pins and harnesses. I replaced the two large electrolytic capacitors on the solenoid driver board, re-capped the sound board. I added NVRAM to the MPU and put the recommended NVRAM conversion jumpers in place. I fixed a couple of displays that had a shorted transistor issue, and lastly, I am just now going through the SCR's as I have a few lamps not triggering.
My MPU board has no corrosion as the battery was removed in 1999 and the service tech neutralized and cleaned what little damage was done on the usual part of the board. Tech did a nice job and documented the fix.
At some point, someone installed a Rottendog rectifier board.
Before and after the minor repairs, this issue comes up where if I leave the game on for a long period of time, assuming idle, it locks up. When I power-cycle it, it won't boot. I have to "let it cool" for 20 or 30 minutes before I can boot it again. The high scores and credits also get wiped!
Something must be overheating. I suspect the 5V regulator area on the driver board.
I will set up two multimeters (that's all I have) and periodically watch 5 and 43VDC lines to see if they go haywire and lock the MPU again.
Anyone know of a solution to this weird issue? Otherwise, the game is fine.
