(Topic ID: 264176)
Bally Playboy GI lamp socket polarity during PF swap
By tomdrum
76 days ago
  • 6 posts
  • 3 Pinsiders participating
  • Latest reply 74 days ago by BigAl56
#1 76 days ago
I'm swapping a CPR Playboy PF and installing new 1/8" braid and new lamp sockets. I finished the feature lamps and are now on the GI circuit. I
noticed the braid on the old PF goes from the upper lug on the sockets to the lower lug on some sockets. Isn't one lug on each socket power and the other ground? Noticed the old wiring seems to overlap on both sides. Note in the picture, socket in foreground is wired to the upper lug and it directly leads the lower lug of the next socket.
#2 76 days ago
Quoted from tomdrum:
Strictly speaking, for G.I. it doesn't matter because the lamps aren't directional. But for the sake of consistency, I too would orient the sockets the same where possible.
Generally you'd want the outer part of the socket connected to ground and the tip connected to 6V, but that's inconvenient for the feature lamps in these games which are opposite and leave a lot of naked metal at the lamp sockets sitting at 5.4 volts.
#3 76 days ago
Quoted from Quench:
Out of the wiring loom at the top for the GI there is a green and red wire leading to power side of the 1st socket and an orange and white wire leading to ground of it's 1st socket. Seems really inconsistent since they flip a few sockets down the chain.
#4 76 days ago
You can see in that picture above the lug connected to the outer frame of the socket is the one stapled to the playfield. If you're "correcting" the socket orientation, you want to make sure that lug is the stapled one so the socket has better stability when installing/removing lamps and can't cause any accidental shorts from too much down force.
#5 76 days ago
Quoted from Quench:
Absolutely will be stapling both sides of sockets when possible.
#6 74 days ago
Bally GI is AC direct from the transformer. There is no polarity and you can run the braid wires however is convenient.
$ 19.99
PinballElectronics.com
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 149.95
Allteksystems
$ 119.95
Allteksystems
$ 50.00
$ 9.00
