Hey I'm the guy that visited Doomer & his Wizard!.
The score motor was very sluggish and had the proper voltage applied to it. I was going to disassemble to clean it but it was riveted together. The product I used was "Super Lube All Purpose Oil" https://www.pinballlife.com/index.php?p=product&id=4499 only pouring some into armatures shaft hole. after running a few time it was working pretty good.
That got it so we had a playable game.
the player up unit was sluggish as well and Super Lube synthetic grease was used on the hub & rivets after using "the magic brush" treatment (dremel tool with wire brush)
I was getting fatigued and couldn't wrap my head around the flags. I recall the number 3 target was the only one that worked properly. it would flip ONLY when the standup target called it to flip and would un-flip when the ball was rolled-over the right lane
#1 would flip and unflip with the standup it would also unflip with the right rollover
#2 would flip with the standup and wouldn't unflip with right rollover
#3 again would flip with the standup and only unflip with the right rollover
#4 would flip with standup and not unflip with right rollover
the schematic was there but again I was tired the manual would probably describe the order of operations (relay/score motor-wise).
I didn't look at the "coin count" stepper unit for dirty contacts and would suspect that's where the credit situation lies
It is a beautiful game and was glad to help get it to where it is play-wise. was also a pleasure to meet Doomer I think you will be able to get this machine dialed in nicley.
