Game was playing fine, then one day flipped it on and it will not boot.
I am getting the first flicker, followed by flashes 1, 2, and 3. I am not getting the 4, 5, 6, and 7th flash.
I am using a new altek MPU, and even swapped in another altek MPU and got the same results. (on one MPU the "Over voltage" red led stayed on, on the other it did not come on)
I also swapped in a known working bridge rectifier boad and solenoid board with no change in behavior.
Here are my test results for the Bridge rectifier board
TP1 - 7.7 VDC
TP2 - 186 VDC
TP3 - 16.03
TP4 - 6.3 VAC
TP5 - 45 VDC
Here is what the values should be.
Although these values are not technically correct, I have been playing the game fine and I believe these were the readings I have gotten before.
I also tested the TP's on the Solenoid Driver board. Here are my results
TP1 - 5.2
TP2 - 135
TP3 - 5.1
TP4 - 188
TP5 - 15.95
Here is what they should be:
The MPU does not have 5 volts after the 3rd flash.
I repinned every connector on the Solenoid Driver Board (and most on the MPU), but nothing changed.
What should I check next? I am stumped. Thank you!
