New! Dark mode!
(Topic ID: 254455)
Bally paragon
By Mountford
1 year ago
  • 9 posts
  • 6 Pinsiders participating
  • Latest reply 1 year ago by Skidave
    #1 1 year ago
    Hello guys, I have had this game sitting in the shed for the last 23 years and have finally got it up and running. I have replaced both the rectifier and MPU boards. I have had it running but after a couple of days the playing lights aren’t working as they used to. The lights don’t cycle in sequence as they used to and tend to flicker with some staying on.....any ideas?....lamp board module....earthing problems....seems to be the scoring lights rather than the illumination ones....thanks
    #2 1 year ago
    Welcome to Pinside!
    The light sockets are poor on this era of Bally. Header pins often need to be done but since you've replace the MPU maybe not.
    http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Lamp_problems
    #3 1 year ago
    Cool thanks for that I will make a start there and see if that solves my problem
    #4 1 year ago
    By the looks of the displays on the backless you likely have connection problems. Sitting in the shed for 23 years....yeah, corrosion. You could try cleaning the header pins on your MPU but you may end up having to replace them and the female connectors as well.
    #5 1 year ago
    Just pulled the lamp driver board off and the tracks on the back of the board look like this.....could be an issue...?
    #6 1 year ago
    Quoted from Mountford:
    Just pulled the lamp driver board off and the tracks on the back of the board look like this.....could be an issue...?[quoted image]
    Get a new board.
    #7 1 year ago
    The lamp driver board doesn't look good, but that is not the reason your (score) displays are weird. Still suggest you check connections between the MPU and displays. That would be connector J1 on the MPU.
    #8 1 year ago
    touch up the solder on the connectors on the display boards. That should improve the displays. Those tend to crack with time.
    #9 1 year ago
    Looks like battery acid dripped down onto that board. I had one like that. I did a bunch of re-work to save it. Ebay or Altek if you do not want to put the time into the repair.
    $ 4.49
    $ 25.25
    The MOD Couple
    $ 29.95
    Pinball Photos LLC
    $ 91.00
    $ 14.95
    $ 5.00
    Chrome Candy
    $ 89.99
    Playfield - Plastics
    Gameroom Mods
    $ 430.00
    MI Pinball Refinery
    $ 54.99
    $ 68.00
    $ 29.95
    Apparel - Unisex
    The GameRoom Store
    $ 99.99
    $ 19.00
    $ 29.95
    Pinball Photos LLC
    $ 75.00
    DBC Pinball
    The Art of Pinball
    $ 69.99
    £ 49.00
    PinballToys
    $ 49.99
    Bent Mods
    $ 99.95
    pinballmod
    $ 70.00
    Cobra Amusements
    $ 259.99
    $ 45.50
    The MOD Couple
    $ 16.00
    $ 18.95
