I just acquired this machine I know that it worked for the most part before it was stored.
When I turn it on I can hear humming but nothing lights up.
I have I setup manual that says if this happens ( on or more of the 5 anti cheat relays are not making contact. 2 are located on the front door and 3 are on the mounting plate) I cant locate any on the front door. Is there a problem if I somehow lock anti-cheat coil in the picture on. I briefly connected it and it started making noise but then got worried after a second and figured I would check here first. Will a fuse jus blow if a screw up or should I be more worried?
Also in one image you can see an orange and white wire I'm pretty sure it goes to an area that says third coin slot. I assume this mean this wire does nothing and I don't nee to worry about it.
