Does the score motor complete a 180° cycle if you start to rotate one of the cams?
Is the fuse and fuseholder for the 50 VAC circuit good? Those fuseholders are pretty crappy and should be replaced.. But, if the Lock Relay is energized, we know you have 50 volts. If you don't know what I mean by score motor, Just remove the glass an put a ball in the kick out hole. If it kicks out, your 50 volt circuit is good,
Make sure your coin switches are not stuck in a partially closed position.
Make sure all Jones Plugs are fully seated. Coin door, Cabinet wires. Playfield to bottom board and bottom board harness to backbox connectors.
