When setting up a multi-player game, make sure there are at least four credits on the credit wheel if the machine is not set for free play.
If there are enough credits, you'll need to see what sends power to the coin unit step up coil. Check the following:
Coin relay switch - yellow wire and orange/black wire
Score motor switch 3B - orange/black wire and white/brown wire
Reset relay switch - white/brown wire and red/black wire
Make sure these switches are clean and adjusted properly...
For the ball in play issue, you'll need to see what switches send power to the ball count step up coil. This circuit includes the coin unit disc and the player up unit disc. Make sure these two unit discs are operating properly by manually advancing the disc to see if they move smoothly. Check the following switches in the ball count step up coil circuit to see if the switches are clean and adjusted properly:
Outhole relay switch - yellow wire and blue/orange wire
Ball index relay switch - blue/orange wire and red/green wire
Extra ball relay switch - red/green wire and gray wire
Score motor 3A switch - gray wire and gray/red wire
For the spinner issue, check the following:
Clean and adjust the spinner switch if needed -yellow wire and black/white wire
Clean and adjust the spinner relay switch - yellow wire and red/yellow wire
