Old Chicago had been working fine - tuned on this am- credits shown - push of credit button - nothing- reviewing startup sequence but there is none- no activation of coin or credit relay - coins which added credits via either chute normally get "rejected" as coin unit relay on door mechanism not energizing either - only issue since previous day/ normal function was raised machine approx. 1 inch in front to adjust legs height slightly but other than that no sharp movements etc. - Tilt and delay relay not energized - Playfield and Backlights all lit - fuses all good.
Was thinking coin unit switch? But neither is adding credits which would seem odd - but curious for other suggestions. Again, this is not a question of certain features of startup being irregular- its no startup at all all of a sudden. Did all the usual "easy" things- checked and reseated Jones plugs, fuses, etc. Thanks for thoughts.
