I picked up a Nip-It and I have worked through all the issues on it, but now I'm hung up on the last problem; the zipper flippers don't close.
When they are apart, the mushroom bumper that should close them scores 1100 points rather than the 100 points it should. If I manually close the MB (close flippers) relay and manually close the flippers, the mushroom bumper scores the 100 points it should.
The entire zipper flipper-close circuit had been rewired with old 2-conductor lamp cord and the wires were all frayed on the ends. I cut out the old lamp cord and rewired it with proper wire. The lamp cord wiring was done really weird, it ran from the jones plugs to one side of the 1.6A fuse block. One the opposite side of the fuse block, they had both conductors of the lamp cord soldered to the fuse block and each conductor going out to two different switches on the Advance Bonus relay. They then had a second section of lamp cord going from the fuse block to the MB relay. Even though it doesn't look right and the schematics don't show the Adv Bonus relay going through the 1.6A fuse, it works so I put the new wire exactly like the old lamp cord was installed.
I'm still with a game that doesn't close the flippers. I cleaned the switches on the MB relay with alcohol and card stock paper, and verified the relay switches were aligned. They opened and closed properly without needed any adjustments. I cleaned the switch on the mushroom bumper and I cleaned the EOS switch on the zipper flipper assembly and made sure they were adjusted and opening and closing as they should. I also made sure the close-flipper coil is good, and I'm getting 5amp on it like I should. I also verified the wired were securely connected to the coil.
I'm attaching pics showing the new white wire I put in to replace the lamp cord. It goes from the zipper flipper EOS (pic 1) to the bottom left plug (the one filled with solder) on the 16 pin plug (pic 2), to the fuse and on to the MB relay(pic 3). I also put a pic of the EOS switch open and closed (pic 4 &5).
What am I missing? If somebody has a Nip-It and can confirm that the wire I replaced was done correctly or not, that would be helpful too. Thanks -Ryan
20230212_154754 (resized).jpg20230212_154858 (resized).jpg20230212_155018 (resized).jpg20230212_155409 (resized).jpg20230212_155419 (resized).jpg
