I recently acquired a bally nip-it in great condition from a fellow pinsider. I'm trying to fix a couple of issues and clean it up before i gift it to my father.
There are only a couple of issues that I noticed.
1. the open gate relay doesn't fire when i hit the gate target relay is activated
the score is correctly set
the light is on
when i hit the target the relay fires
the contactors meet
I have continuity in the line to the open gate relay
I noticed the hot side of the switch that leads to the open gate relay only reads 36V AC
if i jump the wire directly from that switch it doesn't activate
if i jump it from another switch on the relay it does, the other 2 switches are reading 55V AC
I don't have a #455 bulb yet to put into the delay socket
2. the player up stepper doesn't reset all the way when playing with 4 players
I cleaned it, but maybe it needs lube? do i put the teflon lube on the pads to reduce friction?
3. sometimes ballout doesn't progress to next player/ball
I haven't done a deep test on this but i'm scoring points, yet sometimes i've gotten up to 5 balls in a row before it progressed
4. the left lane kickback is pretty weak
5. there is a small flake from where a bulb melted a spot on the backglass, whats the best way to cover that up, i'm lucky and it was in a black paint section
Looking forward to getting this up and running for a xmas surprise.
