Bally Night Rider (SS) Re-theme as "Whack-That-Mole"
(Topic ID: 204340)
By MrSanRamon
1 year ago
  • 106 posts
  • 18 Pinsiders participating
  • Latest reply 35 days ago by MrSanRamon
  • Topic is favorited by 13 Pinsiders
There have been 114 images uploaded to this topic. (View topic image gallery).
There are 106 posts in this topic. You are on page 3 of 3.
#101 38 days ago
Various Back Box lights are going to be used to also activate sounds: Players 1 thru 4, tilt, game over & match...8 seperate inputs to the Wav Trigger.
Since the Wav Trigger only accepts ground as an input, I can't directly wire the lamps to it.
So I'm using relays to switch a ground path. I got these relays as an eight relay assembly.
Robert
#102 38 days ago
Back Box wiring and my wire harness to date.
Robert
#103 38 days ago
Since there is voltage that can travel from a lit light in the backbox, through the relay assembly back into the harness, a diode is necessary to block reverse current flow.
Since I'm not using a circuit board, I needed to make diode packages to be installed in each wire in the BB harness to each relay input.
Robert
#104 36 days ago
I've finished wiring 8 inputs from the B Box and have everything where I think it will stay.
Overall cabinet view:
#105 35 days ago
Switches on the chime mechanism:
Power Supply and grounding block:
Wav Trigger board and audio amplifier:
Wired Relay Block assembly:
Robert
#106 35 days ago
Finally got the overlay installed today. I used the wet install method, and with help it went on really easily. It's still drying, but should be ready to work with tomorrow or Monday.
Robert
Third Coast Pinball
Displays
PinballSolutions.eu
€ 3.95
Multigame
$ 76.95
Third Coast Pinball
