Trying to help a friend of a friend get his Bally Night Rider working again. So far I have replaced the power module board with the PinHead board from Pinball Resource. I repinned all of the connectors when I replaced the board. I just replaced all of the caps on the Solenoid board. While I had the board out I did the ground fixes and connected TP1 to TP3. I get all 7 flashes on the MPU LED. I believe it may be staying very dimly lit. I can get it to go into the self test menu. During the switch self test it displays #7 which is tilt. It looks like someone clipped all of the diodes to the tilt switches. Should I solder all of them back? Could this be what is preventing the game from starting?
I also have voltages from test points
Power Module
TP1 = 5.89
TP2 = 224
TP3 = 14.82
TP4 = 6.6
TP5 = 45.2
Solenoid
TP1 = 4.83
TP5 = 14.70
MPU
TP1 = 4.76
TP2 = 14.61
TP5 = 4.77
TP6 = 12.53
Where should I go from here?
