What I ended up doing was taking off the fingers and nylon gear shaft/wheel unit. Along with the springs, as pictured. I used a small wire wheel dremel to remove most surface rust. Lots of isopropyl just for good measure.
I also removed the coils, although not nearly as deteriorated as the score reels, so I took a Q tip with iso in the sleeve and plunger, then ended up cleaning the plunger more.
Seems as though more grease like junk was holding it back than anything.
Could it be cleaner and shinier? Yes.
Is it working now? You bet.
I'm doing a HECK refurbishment, not a HEP. As in, when I'm done, this thing will be a heck of a lot better than before!
Keep in mind, this is my first all out repaint project. And its a Night Rider...
I've got a few other projects lined up just waiting also (Bazaar, Space Station, a pitch and bat) so I'm trying to do a good job, but not working with a CQ cab to start. Small steps as they say.
Thanks for riding along with me!
