So, after waiting and waiting on parts.. I finally got to do some work here.
First, I worked on the SDB to take that out of the equation.. and since it was needed anyways.
- Replaced C23 and C26
- Replaced all the headers and connectors (horribly tarnished)
- Did all the standard upgrades (minus the fuse swap)
All the voltages look fine within their ranges.. same as the power reticifier (some are a bit hot.. its a rottendog board).
Then, working on the MPU.. I knew Q2 was bad.. but because there was some signs of corrosion in the area even tho it had clearly been serviced previous because the current battery wasn't corroded. So I stripped the area below U11, did the vingar bath and rinse. (Q2 actually fell apart when handling it) and rebuilt that area. No grey'ing or corrosion was seen outside that area, or under U11 that I could see. U8 looks like it's socket was redone in the previous repair.. but no other corrosion in that area I could see.
After that, the LED worked. w00p! And the behavior in the delayed boot is in fact sitting there waiting for the 7th flash. But I also have a second issue now, all the controlled lamps have a very noticeable flicker. When I put in my other MPU (an alltek) the controlled lamps are fine.
So on the 7th flash.. the incoming 43V is fine.. and it looks fine on the other side of R113 at TP3 (22V). In Clay's guides, he talks about jumping two leads together to fool the mpu into thinking the 43V is there.. and on the bench that didn't seem to have any effect. The one diode in the circuit wasn't testing good (CR49), so I replaced that, and all the Rs looked ok. That really just leaves U14 (a 4049). There was some discoloring that looked like heat damage on the side closest to the big resistor next to it.. but it cleaned up.
Quoted from barakandl:Hard to say what is going on without me being right there at this point. Perhaps the 7th flash is delayed and it takes a moment for the zero crossing to ring through the 4049 chip.... wild stab.
That seems to be the culprit.. of course another part I don't have on hand.. If its just struggling to pickup the crossing point.. think just swapping this will finish off the problem?
Anyone have any ideas on the flickering controlled lamps? Lamp Strobe #2 is tied into the repair area. I can double check the swapped parts.. (R28, R107).. but any idea on the flickering? The symptom wasn't visible before.
I'm not really familiar with the concept behind how the lights are driven from the MPU.
