Using an acid based product to remove and nutrialize alkaline corrosion caused by battery leakage will not
damage potted chips, resistors, ceramic capacitors or diodes. Do not get acid on electrolytic capacitors or
relays.
So you have to use care in the use of acid on your circuit board. Alkaline corrosion follows the tin/lead traces
and creeps up the legs of chips and can get internal to chips and other parts in serious corrosion conditions.
So that is why chips, resistors, sockets and other components in corrosion areas need to be replaced.
Products do not usually indicate the PH number but list components. So you are looking for a product with
HCL as the main component and is usually indicated as a percentage of the total product, such as a 5%.
