(Topic ID: 253657)
Bally MPU -35, problems with booting (no LED flashes)
By frsj8112
5 months ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 5 months ago by frsj8112
#1 5 months ago
Ok guys, i've been working on this Bally MPU -35 board for a few days and it's driving me nuts.
The original Frontier ROM set was not working properly, EPROMs (2716s) were bad, so i converted the board to 2732, so that I could use the EPROMs I had in stock.
Now I can get the board working on my testbench (JAMMA switching PSU) with +12DC, +5DC and ground.
I get 6 flashes on the LED and all seems fine.
When I put the board in the cabinet, the LED gives the initial flash and then it halts.
Put it back on the JAMMA-rig, and it works again.
What in the lords name is wrong???
#2 5 months ago
Bad 12 volts?
#3 5 months ago
I've tried the MPU board from my known working Vector machine and when running that board in the Frontier machine it works like a charm.
#4 5 months ago
Replace J4 header and connectors.
#5 5 months ago
Is 5v possibly a bit low?
#6 5 months ago
It’s weird though when the Vector MPU works fine in the Frontier machine
#7 5 months ago
Measure the 12v and 5v when the suspect board is installed. There may be a short that is loading those voltages down.
#8 5 months ago
I tried the board today in the Frontier machine using Leons test rom and it worked as it should, it was pulsing the LED.
Then I switched back to the Frontier ROM set (2732's) and it did not boot. Tried flicking the power switch a bunch of times and all of the sudden the MPU booted!?
Powered off the machine again and powered it on and it stopped booting again after that.
Really weird
#9 5 months ago
I repatched the MPU so it can use 2532 EPROMs instead and now it works like a charm. Really weird but now I'm happy again
€ 3.95
Multigame
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 50.00
Displays
PinballSolutions.eu
$ 149.00
$ 9.00
$ 44.99
PinballElectronics.com
$ 149.95
Allteksystems
