I am trying to restore a Bally Motordome that I bought from a wire hacker. During the previous owners "troubleshooting" about a dozen playfield wires were cut and hanging. Using the schematic, each switch and light was carefully checked back to the MPU. I found about a dozen power transistors and scr's bad. All were replaced.
All switches and lights word perfectly, that is for about 25 minutes. I consistently have the following lights fail and once the scr's are replaced, it plays again for about 25 minutes:
Q37 (B LAMP) RIGHT THUMPER LIGHT
Q37 (A LAMP) TOP "R" LAMP
Q69 (A LAMP) TOP "M" LAMP
Q41 (A LAMP) TOP "LEVEL II" LAMP
All diodes on the lamps were checked and although tested good, replaced with 1n4004 diodes, and rechecked good.
The scr's originally were 2n5060 and have been replaced with 2n5064.
The game came with a spare 6803 MPU, I made similar repairs to this MPU and have the same issue. After playing for a short time, I loose the same four lights and the scr's are bad. Once replaced all lights work again, for awhile.
All voltages on the Power supply board test good, the MPU voltages test good as well.
I re-flowed all the pins on both MPU's.
I am stumped what to do next. Any advice would be greatly appreciated.
Thank you,
Mike
