Just got my first EM and need some help please. Attached a number of pics. I know the game is not working and just starting to go through some basic getting started guides. Could really a clean set of pics of the inside of the cabinet (top and bottom) to show some of the wiring details up-close. For instance, it looks like the transformer has been worked on as has the fuse block. Also think some of the components in the head could be missing parts, but really not sure. For instance, a couple of the pics of the head show things like one of the scoring units (wrong terms maybe) is missing a sort of spring around the center white hub or maybe on that unit it's not needed.... And there is a coil on the left side of the head attached to the side that doesn't seem to do anything, maybe it is a knocker and missing a part? You can tell from one pic of the bottom cabinet there is some electrical tape around two wires that were cut and just "there". Then there is a fuse holder in the same pic that kinda sits by itself and has no fuse, not sure what that is.
As you can tell, I am lost on this EM. Being a "visual" guy, having a starting point with some pics I can compare to what I have would be GREAT. This is my chance to learn about EM's which is why I got this thing.
Also, the schematic on ipdb.org is not great. Anybody know where I can get a better manual and schematic?
Lastly, for now anyway, how do you know how to connect the three main connectors in the head? They don't seem to be keyed. Assuming I could match the wire colors between the male and female sides, but that is a leap maybe.
Thanks very much for any help!
