(Topic ID: 286190)
Bally Lost World Switch Matrix Problems
By Knxwledge
  • 70 posts
  • 7 Pinsiders participating
  • Latest reply 3 years ago by Knxwledge
There are 70 posts in this topic. You are on page 1 of 2.
#1 3 years ago
Having issues with some switches on my Lost World, and wanted to make a new thread about it separate from my others. When I push the start button it causes other switches to go off. The behavior is as follows:
Pressing the start button with no credits manually advances the bonus score.
Pressing the start button with credits starts the game properly, scores 1800, advances bonus once and lights E and F.
Pressing the start button in a started game with no other credits scores 1800 and advances the bonus once.
In the previous thread, Quench told me it's a short in the matrix. How can I effectively test for this? I've replaced the diodes and caps on E, F, and the diode on the start button. I also do notice that sometimes the bottom bumper goes off when it's not supposed to. I replaced the diode on the bottom bumper switch.
My game also stopped taking credits. I had a button lazily soldered in to give credits, fed through the coin door that quit on me. Connecting the credit switch to another switch increases the credits.
#2 3 years ago
That bottom bumper going off when it isn't supposed to could be the spoon switch itself, adjusted too close or shorting. One test for this is to smack the playfield with an open hand to see if the switch is too close. I had a similar problem on my F-14 playfield where a target was causing phantom switch closures at other locations. There was nothing I could find wrong with the switch, even after replacing the diode - but replacing the switch fixed it. It could have been the holes for the screws shorting somewhere in the switch body to the leafs intermittently, something like that.
There are some switch matrix troubleshooting docs and youtube videos online to help identify phantom switch problems.
#3 3 years ago
Get the Bally test chip from pinwiki burn it and use its switch test which will tell you all the switches that are closed. (Install, get to switch test, and press and hold the credit button.... it will scan through all the closed switches on the displays). Then you can narrow down where your issue is.
#4 3 years ago
First what I think is your easy fix. Pop bumper is probably a bad/missing capacitor. The cap helps eliminate switch "bounce" so if it is bad, the pop bumper can energize more than once. Could also just be a switch adjustment.
Now for the switch issues. Switch matrix issues are tricky. First, since you did some work on the start button, make sure that it's fish paper on the switch is properly preventing the switch from being grounded. If the fish paper on the credit button isn't there, you WILL have issues with the switches.
Next, go to the switch test in the diagnostics. From there you might find a pattern of all switches on a particular row or a particular column are giving you problems.
Next, visually check the diodes on the switches, including the pop bumper. A bad diode will cause matrix issues. Note that you can also test each diode with a multimeter, but to do it right, it takes a lot of time. You disconnect one end and then in diode setting test the the diode both directions. One direction you should get null reading, the other direction .4 - .6. So I wouldn't do the multimeter test to start with. We're trying simple stuff first, so just visually inspect the diodes on the switches for damage or being disconnected.
The difficulty is in determining whether your problem is in the wiring or on a component on the board. To determine that try these steps:
Make sure game is off and turn off all MPU DIP switches. Go to switch test. With this running, disconnect MPU connectors J2 and J3 (switch row and column signals). Connect an alligator clip to J2 Pin 1 (this is column 0 of the switch matrix). Then touch the other end to J2 Pin 8-15 (these are the rows) one pin at a time. Each time, a switch number should show in the displays. It should correspond to the matrix as diagrammed in the manual. Then touch the second end to pins J3 9-16.
Once you have done that, move the first clip end from J2 pin 1 to J2 pin 2 (column 1), and repeat everything above. Repeat this for J2 1-5 (all columns). This will work its way through all columns and rows.
From the above, if a row or column is bad, check the diodes on the switches for that row or column. Also, check the connector for that row. Again, you will need to compare this to the diagram in the manual to know which switches are on which row and column.
If you still can't find the problem, it may be PAI U10 (sends switch data). To test, you can swap U10 and U11 (hopefully they are socketed) and see if this clears the problem.
#5 3 years ago
Quoted from slochar:
Would this produce a different result than the default switch test? The default switch tests gives me '0'.
Edit: can't find this download, can someone provide a link?
#6 3 years ago
Quoted from Pinheadpreacher:
Pic of start button is attached. Fish paper is there but a little unevenly aligned with the other parts of the switch.
I went through every switch how you explained, and each time I got a unique number to appear on the test screen. I stopped writing them down after the first set but from last to first pin I got descending numbers with 0-4 in the 10s place depending on what pin of J2 I had the first connector hooked to.
Tried swapping U10 and U11, didnt work.
I read in a post somewhere that the molex plug of the coin door can cause issues. Maybe I should try repinning that?
#7 3 years ago
Something I realized as well. Pushing the start button doesnt make the ball kick out into the shooter lane. I dont have the ball put in. It makes the bottom pop bumper go off, and when I manually press the contact on the ball trough, the game resets . Replaced the cap on the bottom bumper, didnt help
#8 3 years ago
Quoted from Knxwledge:
Yes, that test ROM will show you ALL simultaneous closed switches. The default Bally switch test will only show the lowest number switch that's closed without telling you about other simultaneously closed switches.
https://www.pinwiki.com/wiki/index.php?title=File:Sco_testrom.zip
The 1800 points and bonus advance are from the other three switches on the same switch return line as the start button (lower pop bumper = 1000 points, dragons den capture ball = 500 points, "C" target = 300 points plus advance bonus).
BTW when you start a game the A, B, C, D, E, F lamps should all illuminate. You've mentioned a few times the E and F illuminate, this is normal. Have you changed the capacitors on the C and D targets, the pop bumpers and the dragons den capture ball target?
Disconnect J2 (playfield switch harness) from the MPU board. Does the start button still misbehave? this will tell you if the problem is on the playfield or not.
#9 3 years ago
Yowzah, time to break out the Evaporust and break down that coin door.
If the start button is not insulated from the rest of the switch you could be introducing a ground to the matrix when you press it. I would replace it.
How does the rest of the coin door look? As bad as the start button? I would carefully tear it down. clean everything, and reassemble. For the record, I would not waste time on the coin door Molex plug unless you see visible signs of damage.
#10 3 years ago
Quoted from Quench:
With J2 disconnected the start button still causes the bonus to advance in attract. I replaced caps and diodes on C, Dragons Den (circled in green), and bottom bumper. No change. I got mixed up about how the game is supposed to act. When the game starts, C is NOT lit
Circled in blue, what is this target called? This isnt the Dragons Den is it?
#11 3 years ago
Quoted from BigAl56:
Yeah coin door is nasty. I wasnt planning on doing a full restore on this machine. Just getting it working and selling it. I will tear it down if I have to but was hoping I could leave it
I pulled the coin door switch out like in pic 2 to make sure it doesnt touch ground. Manually pressing the 2 contacts together still causes issues. Is this a good way to test it? Is this switch hosed?
#12 3 years ago
Quoted from Quench:
Looking at the schematic for Lost World on IPDB, it looks like the lines for the credit/start switch are through the J3 connector A4J3-2 & A4J3-14 & no other switches run on the credit switch lines?
Is it different in game to this schematic with the switches that are marked in red following other lines?
#13 3 years ago
Quoted from Joydivision:
Yeah I was also confused as to how he determined where the coin door switches are in relation to the switch matrix
#14 3 years ago
Reading more of the posts and what you have done, since the game actually boots and starts correctly when you have credits except that it also scores 1800 and advances the bonus I think Quench is right in that pushing the start button seems to activate that entire row. If you are SURE that the diodes are all good and oriented correctly, I'd check to see if the wires got crossed somewhere. Physically trace the start button wires through the cabinet to make sure it goes where it is supposed to. Then check its connector (Quench has it above A4J3-2 and A4J3-14 as coin door switches on Bally went through J3 while the other switches go through J2), check the pin on the board to make sure that there isn't a solder bridge to a neighboring pin.
Curious, when you start a game, do any of the other switches work correctly that are not in the same row or column as the start button?
#15 3 years ago
If the caps dont have polarity (which im 99% sure they dont), then yes all switches in that row have good diodes and caps. I found another switch bug- when I press the switch in blue that I circled earlier, the left sling fires. Other than that, the other ones seem to work as intended
#16 3 years ago
20210121_162551 (resized).jpg20210121_162551 (resized).jpg20210121_162618 (resized).jpg20210121_162618 (resized).jpg20210121_162632 (resized).jpg20210121_162632 (resized).jpg
#17 3 years ago
Caps don't matter their orientation, but the diodes do. Check to make sure they are oriented correctly. Physically trace the wire and see if you can find a place that it is being shorted (touching something metal, touching a lamp return line, etc.). Check the other switch wiring on that row also, particularly the bumper as it is easy for bumper wiring, due to its constant movement, to get messed up. Since it seems most everything is working, and you said you swapped the PIAs and the same problem, the issue has to be the wiring, the diodes, or the connectors/pins.
As for your other issue, if hitting that blue switch fires the LEFT sling, then you may have a problem with row 5 (I4). Does it also score points or award the D target?
#18 3 years ago
With my multimeter I went through and checked for continuity between every blade of the 3 switches in question, the lamps for those switches, the surrounding metal, and the 2 different blades of the start switch. As well as the 2 pins on the MPU associated with the start button to any other pin of J2 J3. Didn't find anything shorted
#19 3 years ago
Could you call me and we talk through this? Might be easier. Might help and might not. If so, I'll send my number and then delete the post.
#20 3 years ago
Assuming those are pics of the four switches on row 6, the bumper and Dragon Den switches look good to me based on schematic. The start button hard to tell since it has different wire colors than the schematic says which isn't unusual for the coin door. As for the C Target, your wire colors don't match what I would expect. Looking at the schematic, you should have a white/yellow which you do, but then the brown/yellow the same as the others. Yours doesn't have the brown/yellow. Instead it has a brown/black. Without physically tracing it hard to know if this is on purpose or if something got miss-wired.
#21 3 years ago
If the 1800 point problem still happens with MPU J2 disconnected, the problem is NOT on the playfield.
With the game off, test the diode on the start button switch (I know you said you changed the diode but lets see if there's some short there).
So long as no part of your body is touching ground, then it's ok. Better yet, make the start button switch contacts touch each other without you making skin contact. Your body can introduce unwanted noise.
The blue circled switch is just a rebound switch that scores 50 points and advances bonus.
The cabinet/front door switches are part of the same switch matrix as the playfield. Same switch strobe and return lines. The matrix switches I marked in red are in the cabinet/front door. The 32 DIP switches on the MPU board are also a part of the switch matrix, difference is they're only read once on power-up.
There's a problem with the switch strobe #0 line (which goes to the start button) somewhere that it's shorted to something. When you hold the start button, the short is causing the software to see those other switches on the same row as active - note this is a *phantom* effect, not a physical issue with those other switches.
I've got to head out but looks like you're getting help otherwise. Good luck!
#22 3 years ago
I see how strobe line 0, the White-Red wire is connected to all the playfield switches in that column, but using a multimeter doesnt give me a short from that wire to any part of either the tilt or start switches. Is this normal?
Send me a PM with your number, or maybe add me on FB and we can video chat
#23 3 years ago
With J2 and J3 connected on the MPU board:
The start button red-yellow wire is the exact same strobe signal as the white-red wire on the playfields outhole switch for example.
The start button blue-white wire is the exact same return signal as the brown-yellow wire on the playfields "C" target switch for example.
I've updated the switch matrix diagram above in post #8 to overlay the cabinet/coin door wiring details.
So technically if you jumper the outhole switch diode (banded side after the white-red wire) to the "C" targets brown-yellow wire, this will activate the start button using the same switch matrix signals on the playfield. Try this and see if you get the 1800 points or not. If 1800 points gets added, disconnect J3 from the MPU board and try again.
You've got some corrective work to do on the coin door.
#24 3 years ago
Quoted from Quench:
With J3 connected, it still scores 1800. With j3 disconnected it doesnt. What exactly does this tell me? I worked on the coin door and got the credit button back to working. My mpu is bugged out though, I might get an Alltek. I think thats whats causing my display issues...
#25 3 years ago
Quoted from Quench:
I misread your post, disregard my last message. Regardless of if J3 is plugged in, jumpering the outhole switch diode to the "C" target's brown-yellow wire scores 1800. I made sure no wires were improperly shorted on the coin door but I'm leaving the cosmetic problems. I also tried tracing the two start switch wires from the coin door to the backbox as best I could and didn't notice any fraying or improper shorting of any kind.
The other 2 switch problems still occurring- outhole switch resets game when pressed, and right 50 pt. target makes left sling go off. Was having a problem with either Coin I or Coin III going off randomly but it appears to be fixed. Changed all diodes in row 1, row 5 and 8 (except for the coin door slam one, but I have the yellow wire disconnected for that one anyway). Poked around with the multimeter to try finding any shorts to ground on the outhole switch, couldn't find anything.
When unplugging J2 J3 on the MPU and trying to replicate the outhole and left sling problems, J2 made them stop happening, J3 did nothing. As expected
#26 3 years ago
So..
When you remove J2 from the MPU board and press the start button with available credits, the game starts and you get 1800 points.
When you disconnect J3 from the MPU board and jumper a wire from the banded side of the diode on the outhole switch to the "C" targets brown-yellow wire with available credits, the game starts and you get 1800 points.
If this is all correct, it points to a problem on your MPU board because you isolated the playfield switch harness in the first test and isolated the cabinet switch harness in the second test with the same result.
The other two switch issues you mentioned in your last post are related to the same problem with the switch strobe #0 signal being shorted.
Remove both J2 and J3 from the MPU board.
With the game OFF, multi-meter set to resistance mode, black meter lead on ground, probe each pin on the MPU J2 pin header and let us know resistance each pin reads. J2 pins 1-5 and 8-15 should all measure the same around 56k ohms.
#27 3 years ago
Quoted from Quench:
So..
I bought an Alltek replacement MPU that's on it's way but for fun I will try to troubleshoot the original. J2 pins all measured around 55k-58k. Pin 7 measured 3.0m but you didnt mention this pin, so Im assuming thats either fine, or cant be accurately measured this way
#28 3 years ago
After putting the start switch back together, I noticed the bottom switch contact (after the band) is shorted to ground when J3 is plugged in and the machine's on. Its not shorted when its turned off, or turned on with J3 unplugged. I pulled the switch back off to double check I didnt mess up the install. I think that MPU is bugging even more
#29 3 years ago
Measuring resistance/continuity with power on will give you false readings.
Post some very clear pictures of the outhole switch from side on. Also some clear high resolution pictures of the MPU board front and back.
Then move all 32 DIP switches on the MPU board to the OFF position. Does the start button still misbehave with the 1800 points?
#30 3 years ago
Quoted from Quench:
https://pinside.com/pinball/forum/topic/bally-lost-world-all-displays-glitching-only-evens-and-more#post-6076046 (pics of the MPU)
These pics are slightly outdated, I did replace the 40 pin socket for U10 recently.
All dips have already been turned off, still getting the scoring issue.
#31 3 years ago
The pics don't fully show J2 and J1 (upper 1/3 of the board).
You got a logic probe or better an oscilloscope?
If yes, with J2 and J3 disconnected, what does it indicate on the switch strobe lines pins 1 to 5 at J2?
If no, what voltages do you measure on those pins?
#32 3 years ago
Quoted from Quench:
Pin 1 is stuck HI, Pin 2-5 show both HI and LO with a probe. I have a scope but honestly not sure how to get it set up properly.
Jumper wires on solder side are because I lifted 4 parts side traces when replacing 40 pin socket
20210129_204132 (resized).jpg20210129_204132 (resized).jpg20210129_204136 (resized).jpg20210129_204136 (resized).jpg20210129_204457 (resized).jpg20210129_204457 (resized).jpg20210129_204459 (resized).jpg20210129_204459 (resized).jpg20210129_204506 (resized).jpg20210129_204506 (resized).jpg20210129_204509 (resized).jpg20210129_204509 (resized).jpg
#33 3 years ago
You need to get rid of that U10 AMI brand 6820 (known for having very high failure rate) with any other brand 6821 or at a minimum swap U10 with U11 assuming U11 is not an AMI.
Could even be the problem or part of it.
#34 3 years ago
I had another one in there with the same issues (if youre referring to U10). Just swapped for testing purposes
#35 3 years ago
Pin 1 is stuck HI
Finally we have a clue..
What activity do you see at the source of switch strobe #0 which is the PA0 signal at pin 2 of U10?
My guess is you have an open circuit from U10 pin 2 to the junction of diode CR43 and resistor R31 (which is under the red S33 activity switch). This results in R31 (which is a pull-up resistor) constantly pulling strobe #0 Hi.
Having said that it should also be causing lamp issues and player display 1 issues.
#36 3 years ago
Quoted from Quench:
U10 pin 2 is HI LO. Band side of CR43 is stuck HI, other side is HI LO. Side of R31 which is shared with R31-R38 is stuck HI (5v side), other side which is connected to non-banded side of CR43 is HI LO. Looking at the schematics, this would indicate CR43 is bad, right?
#37 3 years ago
Provided that J2 and J3 are disconnected, then no.
If CR43 was open circuit, J2 pin 1 would indicate Low via the pull-down 56k ohm resistor at R132.
If CR43 was short circuit, then banded side would be pulsing like the non-banded side.
Your previous 56k ohm measurement on J2 pin 1 with respect to ground did not indicate any short after the banded side of CR43.
Please confirm 100% that all measurements since post #31, connectors J2 and J3 have been disconnected?
Remeasure the banded side of CR43 but this time flex the board while doing so, especially around U10. Any change in response?
How much resistance do you measure between pins 1 and 2 of J2 and also pins 1 and 2 of J3?
There's no pics showing the back of the J3 pin header. Can you see anything amiss there?
#38 3 years ago
Quoted from Quench:
Solder side of J3 looks fine. I didn't realize I needed to do the tests in post #36 with J2 J3 unplugged. I will redo them and edit this post
Edit: tests in post #36 didnt change with J2 J3 unplugged. Flexing the board and using the probe didnt change the result of the banded side of the CR43
With machine off, J2 J3 unplugged, resistance between Pin 1 and 2 of J2 seems to change every time I test it. I think it finally stabilized at 100k
Resistance between Pin 1 and 2 of J3 = 53k
Pic attached of solder side of J3
#39 3 years ago
So it was still indicating HI on the banded side of CR43?
What variety in readings were you getting? On spec you should have got a total 112k ohms via the two 56k resistors at R132 and R111.
I can't see anything in your pictures or resistance readings to show the signal from the non-banded side of CR43 onwards being shorted to anything.
With J2 and J3 still disconnected and the board powered on, how much voltage do you measure at:
J2 pin 1 =
J2 pin 2 =
J3 pin 1 =
J2 pin 2 =
CR43 banded side =
CR43 non-banded side =
J1 pin 15 =
U10 pin 2 =
U10 pin 5 =
U10 pin 40 =
Unsolder diode CR43. What does your logic probe now indicate on J2 pin 1?
Below is the MPU schematic of the switch strobe #0 signal as it comes out from U10 pin 2 (PA0) signal. Orange trace shows its travel to the non-banded side of diode CR43.
Banded side of diode CR43 onwards trace in green - as you can see there is nothing from the banded side of the diode onwards connecting it high, all connections are to ground.
#40 3 years ago
Quoted from Quench:
J2 pin 1 =
J2 pin 2 =
J3 pin 1 =
J2 pin 2 =
CR43 banded side =
J1 pin 15 =
U10 pin 2 =
U10 pin 5 =
U10 pin 40 =
Flexing the board still resulted in CR43 banded side stuck HI
J2 pin 1 is 2.02
J2 pin 2 is 1.7
J3 pin 1 is 4.9
J3 pin 2 is 2
Cr43 banded is 2.1
Cr43 nonbanded is 1.6
J1 pin 15 is 1.69
U10 pin 2 is 1.69
U10 pin 5 is 1.7
U10 pin 40 is 4.9
My Alltek came. If I have solid voltages on the MPU test points, am I good to plug it in? I dont know if the voltages above are good or not.
Removing Cr43 didnt change J2 pin 1. It's still stuck HI.
As far as resistance on J2 pin 1 and 2, i was getting quite high readings that were dropping quickly. I just retested it a minute ago and it seems to be at 140k, dropping each time I check it
#41 3 years ago
With power OFF and J2/J3 disconnected, measure the resistance across R132 (which is for J2-1) and then R111 (which is for J2-2). Both should be about 56k ohms. When you measure across J2 pins 1 and 2, effectively you're measuring through R132 and R111 in series and should get 112k ohms total.
Should I check R133 and R60 out of circuit?
Check them in circuit first (again, machine OFF and J2/J3 disconnected). R133 and R60 should both measure around 1.2k ohms.
J2 pin 1 is 2.02
At 2.02 volts, in TTL circuits this is a very marginal HI. In CMOS circuits this is neither HI or LO. If you set your logic probe to CMOS you won't get a HI reading.
Please replace CR43 if you have a spare 1N4148 or 1N914 diode.
Yes, go for it!
#42 3 years ago
Quoted from Quench:
In circuit, R132 starts at 52.7k and climbs to ~54k each time I measure it. Would this be caused by the resistor, or could it be caused by the cap in circuit with it?
Quoted from Quench:
1.18k for both
Quoted from Quench:
Don't have any on hand but am going to place an order for my next project, Mars God of War, with GPE. I'm also going to replace R132 and probably the cap next to R132.
Yes, go for it!
The Alltek has fixed all switch matrix issues, and I'm letting the machine warm up to see if the display issues are fixed as well
#43 3 years ago
The caps in the circuit are too small to have this effect. BTW if you're touching the metal ends of the multimeter probes with your fingers, your body will affect the resistance readings.
If you're replacing switch matrix diodes on Mars God of War, then 1N4148 are not suitable. See the current discussion here, particularly the second half of the thread:
https://pinside.com/pinball/forum/topic/need-help-with-system-1-game-slow-response-time-
Just above the J3 connector, unsolder one leg of resistor R59 and lift that leg from the circuit so it's not making contact. Does this make any difference to J2 pin 1 reading HI with your logic probe?
Regarding CR43, you could temporarily try replacing it with a 1N4004/1N4007 diode if you have either.
#44 3 years ago
Quoted from Quench:
If you're replacing switch matrix diodes on Mars God of War, then 1N4148 are not suitable. See the current discussion here, particularly the second half:
On God of War, I honestly dont know what Im doing yet. Only thing Ive done is remove the original black brick battery and clean up a little bit of corrosion. I bought it, the guy told me it had a power problem. Im just putting together my parts list now since the Lost World is wrapping up. Thank you for the heads up.
For the R59 test, should I have a diode in Cr43?
#45 3 years ago
Yes, you need a diode in CR43. If the original CR43 is still there that's fine for this test.
#46 3 years ago
Quoted from Quench:
I will test it, but I think this will be my last shot at fixing this. Its clearly past my skill level haha. It will sit on the shelf as a spare.
One quick issue that popped up, the Dragons Den 5k light is coming on when its not supposed to. After a couple mins it will get stuck on and flicker off. Tried replacing the socket and it made no difference. I replaced Q55 and checked the 2k resistor on the lamp driver board.
#47 3 years ago
Changing Q55 didn't make a difference? What replacement part did you use?
#48 3 years ago
Quoted from Quench:
Well I had changed Q55 a while back, and this problem just popped up today. Im using the transistor from the Big Daddy Lamp Driver Kit, which is what Ive replaced other transistors with as well. 8KS26 CR 105-6R. As for the MPU, I put CR43 back in, lifted R59, and tested voltage and signal from J2 pin 1 with J2 J3 removed. It now pulses HI LO, and voltage is 1.7v
#49 3 years ago
Well I had changed Q55 a while back....8KS26 CR 105-6R.
The lamp symptom suggests Q55 is faulty. Can you swap it with another of the large SCRs on the lamp driver board and see if the fault follows the SCR?
BTW is it a typo that the part number is really a CR 106-6R ?
Alright, this suggests some resistive short between pins 1 and 2 of the J3 connector.
With R59 lifted, pin 1 of J3 is connected to nothing. So with the machine OFF and J2/J3 disconnected, if you do a resistance measurement between J3 pin 1 and J3 pin 2, do you get any reading?
#50 3 years ago
Quoted from Quench:
Yes I think that was a typo. I swapped Q1 and Q55, and the problem did not happen in the F target light (which is fed by Q1).
On the MPU, Im getting open. 1.0m climbing to 1.7m on resistance. Once again inconsistent readings
$ 10.95
$ 12.00
$ 8.00
Third Coast Pinball
$ 69.00
Pinball Pimp
$ 69.00
Pinball Pimp
$ 18.95
Retro Electro Designs
This page was printed from https://pinside.com/pinball/forum/topic/bally-lost-world-switch-matrix-problems and we tried optimising it for printing. Some page elements may have been deliberately hidden.
