Lamp driver on my Bally Playboy stopped working, it was working perfectly fine except for at the bottom of the playfield where it's numbered 1-10... #4 wasn't lighting which turned out to be a cracked header pin, I re-flowed the pin and others, checked to make sure none of them got cross soldered, put it back in turned the game on and the first time had no illumination at all, turned it off and back on and GI came back on but not lamp driver lighting. Removed the fuse and it's good, under PF fuse good. Any suggestion what happened.
