Hi Matt
I was feeling anxious, tense the last couple of days - awaiting medical examination, my heart problems - O.K., result of the examination - my heart should function the next 2 to 3 years - maybe surgery at a time - but for the next months I decided not to worry.
To Your Bally Knockout pin (and my snippet of schematics) - thanks for post-6. You SEE the Double-Bonus-Relay engage (when the Center-Lane-Unit is in "right" position (pos-1, -6, -8) - then faulty the relay disengage.
See the snippet - "my green A" - I guess the Unit does not step (within the time of engage - disengage) - but I assume the "my green B, Top-Center-Lane-Relay" engages - then (is entitled to) disengages. Please do this test, please wear rubber gloves - current can kill, ruber gloves hinder current flowing through Your body: First do what You did - watch the Double-Bonus-Relay engage, then disengage - NOW press the armature of the Top-Center-Lane-Relay - keep on pressing - question: As long in time You press - as long the Double-Bonus-Relay stays engaged ?
I would like to use an Jumper-Wire - actually TWO Jumper-Wires - to install them: Toggle-off the pin, unplug the main power cord. One Jumper-Wire is clipped on on a solderlug somewhere - clipped on wire-YELLOW (abundant in the pin, example "Switch on Lock-Relay") - take the other end through the open Coin-Door and let the other end hang loose - not touching metal.
Take the second Jumper-Wire, clip-on at "Self-Hold-Switch on Double-Bonus-Relay, see the short wire running from 'Coil on the relay to switch on the relay' --- yes this switch BUT clip-on on the other blade, solder-lug" - take the other end of the Jumper-Wire through the open Coin-Door an let hang free - not touching metal.
Then plug-in, toggle-on, start a new game - then (wear rubber gloves !) put together permanent the ends of the two Jumper-Wires --- then make "Double-Bonus" - question: Does the Double-Bonus-Relay stays pulling ? Well this is just a test - You can not play this - as the Double-Bonus-Relay by now stays pulling until You take apart the two Jumper-Wires.
I do have Jumper-Wires with "built-in Toggle-Switch" - but for once doing such a test You can do as written above. Greetings Rolf
