Quoted from bigbadford91:Are all the fuses for the machine supposed to be slow blow fuses?
I'd look into that, EM's are usually fast blow.
Mine (Bally QB) inside the coin door L/S are fast blow type never an issue. Not sure on others.
PBR has fuses > http://www.pbresource.com/fuses.html#reg < and holders
There was a slow blow fuses in there when I bought it and it was blown. The schematic doesn't show slow blow fuses but I wanted to make sure.
Made some progress this weekend. Got the coin door wiring and short all fixed. Replaced all the fuses with the correct ones. I thought I could get away with using the original fuse holders but I'm going to have to replace those. The tilt relay was replaced with the wrong coil. It is too short. Can I put a spacer between the coil and bracket to place the coil closer to the armature plate? Or am I better off getting the correct coil? Also, my flippers have two different brand coils. Is it better to have the same brand coils for performance or does it not matter?
This page was printed from https://pinside.com/pinball/forum/topic/bally-knockout-coin-door-help/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
