(Topic ID: 172987)
Bally kiss restoration
By amkoepfer
  • 153 posts
  • 22 Pinsiders participating
  • Latest reply 8 months ago by amkoepfer
  • Topic is favorited by 19 Pinsiders
    There have been 70 images uploaded to this topic. (View topic image gallery).
    There are 153 posts in this topic. You are on page 2 of 4.
    #51 3 years ago
    stopping work on kiss for a bit, i need to get a meteor ready to go, and its a bit more of a job than i thought it would be. the g.i. keeps going out, ive replaced the driver board with one from kiss, that fixed it, then it went out, so i put a new alltek driver board in. that worked, then stopped, then worked. i think the rectifier board may be causing it. i did a flipper rebuild, clean and wax, and changed the drop targets. i have a newfound hatred for early stern drop targets. it took forever to change them. now a few lamp sockets are bad, and a few other small issues, but its looking good. ive never really played meteor, are the meteor drop targets supposed to reset after they are all dropped? this only resets after the ball drains.
    #52 3 years ago
    Nevermind. I just watched a tnt video on it. Yes it is supposed to reset. I guess ill add this to my list
    #53 3 years ago
    I see! Thank you!
    #54 3 years ago
    Wow!!! I joined this site for this very machine. I cannot wait to see how this comes out!!!!
    #55 3 years ago
    You and me both! Its my first full restoration. Its taking forever due to a full time job along with other pinball jobs, but its looking nice!
    #56 3 years ago
    Took a break to finish meteor, that leaves tomorrow, then ill get back on kiss finally
    #57 3 years ago
    Meteor is gone. I should have taken pics!!! Now im switching to the other kiss to get that ready for sale, then back to the restoration. He changed his mind and has decided to go with the updated playfield board for the kiss lights, so that will make it that much nicer!
    #58 3 years ago
    Ive taken a small break from the restoration die to the holidays, im hoping to get a decent amount done next week. The sling assemblies spent 4 days in evaporust, tomorrow it will go in the ultrasonic cleaner for a couple days. Its coming together, but man is this a long process
    #59 3 years ago
    Nice work so far.. looking great!
    Kiss is a favourite of mine, and is the game that started my obsession so it was my holy grail game for many years.
    I finally found a project one for a decent price (stumbled across it i should say..lol) after a 20 year search, restored it and it's a definite keeper!!
    #60 3 years ago
    After this is done, im really going to want to buy it off the owner, but i dont think ill be able to afford it!
    #61 3 years ago
    Does anyone have pics of the j1 j2 and j3 connectors with the wire colors? None of my power boards or connectors are hooked up so repining the second machine is becoming an issue! The j1 connector from marco is 8 pin, but the original is 9 pin
    #62 3 years ago
    Here is something that should help.
    #63 3 years ago
    Thanks ken, just what i needed!
    #64 3 years ago
    I just re-pinned J3 a couple hours ago in my KISS...I'm not in front of the machine (it's not at my home), but I can say that past the key (#7) position there is definitely a N/U - I just can't remember which position....but definitely only 18 wires in use on J3 for my KISS....off hand, I would assume it was one of the grounds between 14-20....
    #65 3 years ago
    Thanks sonic. That image ken posted looks accurate to me, wich also shows 7 as nu. My connectors should show up today so hopefully ill have it up and running in a couple days. Went back to the playfield swap for awhile last night, but needed to do ground wire and i couldnt find my stapler, so i stopped! Im hoping to really dive back in shortly and get it done!
    #66 3 years ago
    Right...#7 is N/U (Key), but you'll find that there is one more - so you don't tear it apart looking for a missing wire - you'll only terminate 18 of the 20 positions! Let us know how it goes!
    #67 3 years ago
    Kiss clean up/shop out is about done, trying to figure out aux lamp driver board, only part of the kiss lights work, only about 3 flash. I think its the 3 chips on the board, but not sure yet. Ill take pics once its all done, but it turned out pretty nice!
    #68 3 years ago
    Quoted from amkoepfer:
    If you have not re-pinned the connectors it is much more likely to be that.
    #69 3 years ago
    No i have not on the aux lamp driver. Ill give that a try, thanks!
    #70 3 years ago
    I repinned the connectors, and it still isnt working. Im thinking it has to be 1 of the 3 chips that controls the flash
    #71 3 years ago
    You're talking about the KISS in the back glass that flashes?
    By the schematic, the K and I flash through the U-2 chip and the two S flash through the U-3 chip on the aux lamp board. And check for loose grounds on the back of the lights as well. True confession: I spent hours troubleshooting and "fixing" a lamp driver board before I finally determined that all the bulbs were burned out. Good luck!
    #72 3 years ago
    Ues, i replaced the lamp sockets and made sure those were good. The u2 and u3 i believe control the letters, and u1 controls the flashing, cycling through the letters. (I think)
    3 months later
    #73 2 years ago
    Finally back into the restoration. Most of the ground braid is ran, pop bumpers and slingshots are done. Getting close to the wiring harness. Decided to do the upgraded light board so i have to install that
    1 month later
    #74 2 years ago
    Yellow target bank is installed gate diverter, and updated lamp board
    #75 2 years ago
    Are you redoing the scoreboard by chance?
    #76 2 years ago
    All light sockets, ground braid, and possibly displays will be brand new
    #77 2 years ago
    I need a huge favor, then, if I might. I have a customer in Australia who is doing a "Miss World" conversion of a KISS machine and needs to create the score board from scratch. When you have it stripped, if you could just trace the outline and the locations of the light sockets it would be a great help. I'll gladly pay the shipping to my house so I can pass it along to him.
    Shawn
    #78 2 years ago
    Ill see what i can do, it will probably be awhile though, since i have to get the playfield done first and order the new sockets.
    #79 2 years ago
    I appreciate that, and there is no rush. Thank you.
    Shawn
    #80 2 years ago
    Does anyone have a part number for the sling leaf switches? I need to order some new ones, but i want to see if pbr has them before going through marco
    #81 2 years ago
    Im also looking for a part number on the pop bumper scoop switches. Thanks. Getting down to getting the last few switches and sockets.
    #82 2 years ago
    You can just send an email to PBR and advise them .....
    I need the following parts for a Bally KISS machine:
    4 - pop bumper scoop switches
    2 - sling leaf switches
    and Jimmy will do the rest! I never provide part numbers to them and have never had an issue!
    However, PBR is closed this week so you need to wait till the 10th to order!
    #83 2 years ago
    Thanks, i always try to put part numbers on there, but thatll be a lot easier! I didnt realize they were closed until monday, so i guess ill take a few days off of it or work on other parts. I have the lights for the pop bumpers in, but i still need to staple them down and put the ground braid in that area, but my stapler is too big to fit in between the bumpers so i have to take them apart again to get that done. Thanks for the info!
    #84 2 years ago
    Pbr and marco are out of stock on the pop bumper spoon switch stacks. Does anyone have any new ones they would sell? Part number (i think anyways) is a stern number sw476. Im looking for 4 of them. Id like new, or i can build my own or clean my current ones. Can anyone with a kiss game tell me if the spoon switch for the pops has a capacitor on it? I have 2 games right now, one has a cap, the other doesnt
    #85 2 years ago
    I will be home in a couple hours and can check mine. Can't remember off hand as I rebuilt my pops as well when I restored mine.
    #86 2 years ago
    Quoted from Mk1Mod0:
    Shawn
    He could scan it for you, and then you would have a great reference.
    You can also buy them already made, for $22.
    http://pinballreplacementparts.com/products/product-0002
    M0ZFNUZFRjZCRDU5RDU1RjNCQkE6MDEzZGM4OWEwMDBjNzVjZjg0MGRkZjAzYzNiNTg3ZjE6Ojo6OjA= (resized).jpg
    #87 2 years ago
    Quoted from vid1900:
    I believe he needs the backbox lights, not the kiss matrix on the playfield
    #88 2 years ago
    Quoted from Pickle:
    Thank you. Im pretty sure they do have them if im reading the schematic correctly
    #89 2 years ago
    Correct. The back box insert. I bought one of those p/f inserts for my own KISS play field from PBR. Great product.
    Shawn
    #90 2 years ago
    Shawn, im getting close to the backbox. I ordered the sockets today, im hoping to finish putting the wiring harness on the playfield this week, then ill be moving on to that, so hopefully not too much longer
    #91 2 years ago
    No problem, I really appreciate it. No rush at all.
    #92 2 years ago
    Rails are back on the playfield, just have to put in the spinners and two more switches. Started labeling and cutting the harness today. Its getting close! Ill take some more pics tomorrow
    #93 2 years ago
    Ok, i decided to go back through and change all the rollover switches. It has almost all new parts, why not do that too. I may be overthinking this, but changing the diodes on the switches, the original is a zener diode, i can change that to a 1n4004 right? And if so, which way does it go? (The black band on tje zener diode, is that power or ground?) I know the band on the 4004 is the power side, but looking at other diodes on it it looks like the band on a zener may be ground. As i said, im probably overthinking this
    #94 2 years ago
    Many Bally's from this era shipped with 1N4148 or 1N914 diodes installed on the leaf switches. While these may look similar to some Zener diodes, they're definitely not Zeners. 1N4004 will work just fine for this purpose. If that's what came installed on your switches just leave them.
    Pinwiki has a good breakdown of diode orientation with respect to the strobe and return lines:
    http://www.pinwiki.com/wiki/index.php?title=Bally/Stern#Proper_Location_of_Wiring.2C_Diodes.2C_.26_Capacitors
    And make sure you install a .047uf ceramic cap on all rollover switches and standup targets, otherwise the MPU will miss a lot of fast switch closures!
    #95 2 years ago
    Thank you. The schematic says it should be a 4004, but it looks like a zener to me. Ill check pinwiki for orientation on it. Good idea on the cap too!
    #96 2 years ago
    That was the info i needed. Thanks again
    #97 2 years ago
    The Aux lamp driver board in Kiss can cause some pretty-wacky problems if it isn't working correctly. Stuff I wouldn't have thought would have anything to with it.
    Mine would start-up nice and play great. The K-I-S-S would flash properly and everything would function 100%. Then after about ten minutes the machine would go berzerk. GI would go out, displays would go flaky. Really bizarre stuff. It had me stumped for quite a while until I removed the Aux lamp driver and realized it was the problem. I had it rebuilt for $15 and haven't had any issues since. It's a great machine. One of my "keepers".
    #98 2 years ago
    I bought 2 new aux boards, i fixed up one kiss awhile ago and was driving me crazy for the same reason. This game will have all new boards, even new power supply board. The updated aux lamp driver works great by the way!
    #99 2 years ago
    Harness is ready to move. Im waiting on the rollover switches, diodes and caps to show up first, and im going to replace all the old diodes still with new. I have a lot of soldering in my future!
    #100 2 years ago
    Quoted from erichill:
    The .047 uf caps youre talking about... the schematic calls for .05, what is the voltage? Ive seen a few different ones and want to make sure i get the right parts
    $ 5,799.00
    Great American Pinball
    Pinball Pimp
    $ 11.95
    $ 48.00
    $ 245.95
    Allteksystems
    Pinball Photos
    Metal-Mods
    $ 1,099.00
    $ 28.50
    $ 7,299.00
    Classic Game Rooms
    $ 999.00
    $ 139.00
    $ 248.85
    PinWoofer
    $ 47.00
    The MOD Couple
    $ 17.50
    Playfield - Plastics
    $ 199.99
    $ 26.50
    $ 14.95
    $ 48.00
    $ 209.99
    PinballBulbs
    $ 299.99
