Working on a Bally KISS that I got running today but the only thing not working is the playfield GI. So I pulled the rectifier board and the J1 connector was all burnt up. Replaced that with new male header pins along with trifurcon pins on the connector. Plugged it in and the playfield GI was working. Turned off the pin and turned it back on and the playfield GI was not working again. Reseated the connector and it was working again. So I pulled the connector to check the AC voltage right at the male pins to see if the problem was in the connector or on the rectifier board and I was getting 6.8v AC on pins 1/5 and 2/8. As I was measuring the voltages at pins 2/8 with my DMM, my probe shorted across (I believe) pins 7 and 8 and I saw a spark. After that I'm not getting any AC voltages at those pins anymore. GI fuse is good (GI in the backbox still working) and everything else in the machine is working fine.
The board at J1 was pretty burnt up but I did continuity tests on all the pins when I installed the new male header pins and everything was good. Perhaps the pushing/flexing of the board when inserting/removing the connector broke a connection. The machine is at a remote location so I don't have instant access to it.
Looking for any ideas on what might be going on. Thanks.
