(Topic ID: 197916)
Bally Judge dredd - how to remove side button?
By ViperVS
2 years ago
  • 7 posts
  • 7 Pinsiders participating
  • Latest reply 2 years ago by ForceFlow
#1 2 years ago
I can't figure out on how to remove the red side button (internals) for bulb replacement. I tried to rotate the inside part clockwise and anticlockwise, but it does not move at all.
Has anyone done this before?
#2 2 years ago
I 2nd this, tried for the first time on my No Fear and couldn't figure it out, I messed with it for a couple minutes and gave up.
#3 2 years ago
First try to push the spring back so you can bend the two white "legs".
Bend the two white "legs" inward and push them both inside the black housing.
This would make the whole white part to slide in and come out the other end along with the red lens.
#4 2 years ago
I believe they snap in, should be able to wiggle L/R while pulling.
#5 2 years ago
Internals snap in only they are very hard to pull out. Takes more force than you would think to pull the lamp unit straight out but they wont break.
You can try a little side to side motion while pulling but not to much of that motion.
It also takes some force to snap them back in to place.
#6 2 years ago
They snap in & sometimes you have to snap them completely off to get out
#7 2 years ago
I usually have to pull hard and twist a little bit back and forth. Just be careful what you grab so you don't snap one of the legs that switch is mounted on.
$ 40.00
$ 279.95
Pin Stadium Pinball LEDs
$ 29.50
Playfield - Plastics
