Quoted from Skybug:Yes, all of these sheets came with my machine and they are all marked "Joust" except flipper- zipper assembly.
I only now discovered the high score adjustment chart which was taped to the back of the backbox cover.
Add a Ball conversion has two changes:
- Hi-score feature plug in Shoot Again position
- Match feature plug in Off position.
I'm trying to figure out, if I set it this way, if the knocker will ever work?
Looking at the schematic , when you change to the "shoot again" it doesn't activate the credit reel when you reach the high score threshold. The knocker (or sounder) would only activate if you add credits with a coin.
Thank you for the documents Skybug I would think in this position for a tournament setting it would be considered an extra ball as opposed to what I'll call a "true add-a-ball" from scoring "wow's " .... but I could be wrong.
Do you have score cards that say "add-a-ball" for each score of xx,xxx for the apron ? Inkochnito 's cards are all replay cards
Where the machine I have is now is at a pinball club so I'll probably leave it set for replay there as different tournaments are held. but would consider this add-a-ball change when I bring it home.
