Hi there, help required to identify fault with 1 points reel being held in reset (coil energised). Has anyone got a schematic diagram so I can trace?
Many thanks.
Many thanks.
Quoted from blightyJoust:elp required to identify fault with 1 points reel being held in reset (coil energised)
You mean it's doing that during start up?
Hi blightyJoust welcome to pinside.
The most likely cause is a stuck playfield switch. You can verify that as the cause by temporarily unplugging the playfield jones plugs and see the problem disappear.
Quoted from HowardR:The most likely cause is a stuck playfield switch.
... esp. if pts. are running up during the game.
Quoted from currieddog:You mean it's doing that during start up?
It completes the reset and zero's all score reel's then player 1 score reel 1 points starts to buzz (has burnt a coil out). I will try and locate a playfield stuck switch as suggested by HowardR
This page was printed from https://pinside.com/pinball/forum/topic/bally-joust-1969-1pts-reel and we tried optimising it for printing. Some page elements may have been deliberately hidden.
