Hi
Is there anyone out there could help me out with what should be a simple scoring problem please?
The hundreds are not incrementing the thousands reels as they pass from 9 to 0
This happens on both players so it doesn't look like a problem at the reel switches, although I did check the 9th position switch on the 1st player hundreds reel and that's OK
I can see that the thousands relay can be activated via a switch on the hundreds relay, but that checks out OK too, as does the feed to that switch from the 9th position switches on the hundreds reels
Since the wire colours inbound to the 9th position switches on 1st and 2nd player hundreds reels are different colours that would seem to suggest the problem is elsewhere (since the problem is common to both players)
Without a schematic that's where I've come to a stop - I really could do with seeing the circuit drawn as I'm not that familiar with Bally games - most of mine are Gottlieb or Williams
If there is anything obvious I've missed so far please point me in the right direction.
And if anyone could share with me the section of the schematic that covers the scoring (or the whole schematic) that would be fantastic
Many thanks
David
