I am doing a mini restoration on a Bally Hokus Pokus, and Iam trying to determine if I have an issue with the scoring reel rest function, when a game is started.
When the game is started, the scoring reels will start cycling and properly change to all zeros. But after the reels all show zeros, the "reset Scores" relay and the scoring motor will continue to cycle for what seems to be an excessive amount of time. I am thinking that once the reels all reach zero, then the "Reset Scores" relay should stop cycling. Am I mistaken?
The number of cycles can very any where from two additional cycles, to ten additional cycles. But the game will always reach play state after the "scores relay" has stopped cycling. It does not seem to get stuck in that cycle, and never end.
The switches on the scoring reels appear to be properly adjusted, and I believe they are in the proper states for all zeros on the reals. But there must be an elusive switch somewhere that I cant seem to find. Or maybe all of this is normal operation.
Can someone please point me tell mne f this is normal, or point me in the direction of a solution?
B
