Hello my Hokus Pokus stopped scoring 100 reel on both players ! it still registers a bonus on the rollovers and registers the lights abcd . what should i look for ?? thanks
1) Does the 100 Point relay get activated when it should?
2) Does adding 10 to 90 activate the 100 Point relay?
3) What happens if you manually activate the 100 Point relay?
Does your machine have a 2nd player relay in the backbox? This relay is full of make/break switches that transfer power from 1st player score reels to 2nd player score reels. Check for a switch that all 3 blades are touching. Adjust wrong touching blade.
Quoted from pinballdaveh:Does your machine have a 2nd player relay in the backbox? This relay is full of make/break switches that transfer power from 1st player score reels to 2nd player score reels. Check for a switch that all 3 blades are touching. Adjust wrong touching blade.
He said it won't score on either player which points more to the 100 point relay. That second player relay would cause scoring on both players. I unfortunately have experience with Bally two players doing that
This page was printed from https://pinside.com/pinball/forum/topic/bally-hokus-pokus-100-reel-not-scoring- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
