My Hi-Low Ace machine was working perfectly this past October. I covered it up and when I recently fired it up discovered that special feature sticks on when obtained. Sometimes stays locked on till the counter maxes out, sometimes just a few extra games. When the special feature sticks on, the score motor continue to rotate and the alternator relay keeps actuating/ switching the special lights back and forth. The special relay is free and moving easily. I checked the 4 switches that score on a special and they seem in proper position and working order. The game plays perfectly other than the sticking special scores.
The machine is in my shop which is heated with wood. I thought that perhaps some drying occurred and switches were in need of adjustment. To that end I tightened all the screw on the main score motored. I also check that all the Jonas plugs were in tight. No joy. Problem persists.
This machine was DOA when I got it a little over a year ago. With past help from this forum I was able get her back in shape and played hundreds of times.
I would be very grateful for any thoughts on where to looks to fix the current problem. Thanks in advance. Bill
