Just wanted to wrap up what I started here, I've ordered a replacement plunger / collar from pbresource along with a few coils that appear to be past their prime as well as the schematic.
What I did in the meantime is adjusted the 00-90 match unit step up arm bracket ever so slightly by loosening the two Phillips screws ( you can see beside the spring in previous post) and the screws slid down to the bottom of the slots, now the unit only moves one gear tooth at a time allowing the bonus to alternate. Once I got that straightened out I found that both of the low card bonus lights were not lighting. On the right side it was a blown bulb, which after the holder was clean and bulb replaced lite up. On the left side i tested the bulb and it was blown too. Checking the voltage in the holder I got almost 30 volts! huh? So without a schematic handy. (I have the 'Fore' game schematic , which was very helpful at figuring out how the bonus alternator in a 'well if that works here then....this must go here' kind of way) I began to manually follow the wire and found that the 'low card bonus reset relay stack had a shorted connection'. Fixed that and while I was mucking around in there I discovered the Hi card bonus reset stack clear plastic seven slot radial bottom switch actuator bally part number C-709 (unavailable from pbresource...sigh) base had broken off. So what to do? Found a 7/16 rubber vacuum hose, cut enough off to cover the width of the actuator, slit the hose and slipped it over the busted end...well lord thunderin it worked....for now. Found one on flippers, part is cheap enough but shipping is ridiculous. If someone wants to pick one up local and bring to toronto...
The other thing that was needing adjustment was the 100,000 point light relay which didn't work during game play. It resides on the last position of the 17 trip relays reset motor assembly. It appeared the plastic cams where they interlock and drive each other are slightly degrading, so that by the time the bakelite plate hit the notch and stopped the motor the 100,000 point cam didn't make it to its release point. Two set screws held the bakelight collar in place, loosen them up, backed up the plate a fraction and tightened them up.
Now the game seems to work 100%. Thanks again for all the help!
Just for fun see the picture of the bolt? That's a leg from a old washing machine I found at the dump. Perfect fit for leg levelers and box hold downs..
