Thanks for the pics, they are very helpful. After looking at these, I have two suggestions:
1. On the ball count unit, the adjustment of the zero position switches look pretty good; however, I am wondering if the make-break switch is making good contact with the open switch blade when the ball count unit is stepped up one tooth from the zero position. Right now, the switch gap looks very large to me, so it would probably be good to check the action of that switch, and confirm all is well.
2. The Game Interlock Relay appears to be out of adjustment. It looks like this relay is "kind of" latched, but unfortunately the latch positioning of the two armatures looks wrong. Also, it looks like there are switches on the relay that are out of adjustment. Here is a picture with pointers to the issues I'm talking about:
The red arrow points to the place where the relay armature latching occurs. The vertical plate should either be totally engaged in the plastic hook that it is touching, or totally dis-engaged from it. Your vertical plate is resting right on the edge of the plastic hook, and that is no good. Check to see if you can fully latch the relay by hand, by pushing the horizontal armature tighter against the coil. If the vertical plate won't latch fully, you'll need to adjust the relay so that the vertical plate lands fully in the hook when the relay is latched, and also so that the vertical plate is totally off of the plastic hook when the relay is released.
The two yellow arrows point to where you have two switches out of adjustment. When I look at the other switches on this relay, they show that the relay is in the latched position. In this position, the two switches with the yellow arrows need to be open, but they are still closed. Note that this may be happening because the relay isn't fully latched (the vertical plate isn't fully in the plastic hook) but in any case, once you fix up the adjustment of the relay latch, you'll need to check the switches on this relay and adjust them as needed so that they make and break properly, depending on whether the relay is latched or tripped.
- TimMe
